Hi all,
Ever since we added a 7030 controller (running ArubaOS 8.6.x.y) into our network our APs are showing a steady amber system status LED which according to the documentation means that it is PoE is either limmited with IPM or 802.3af PSU.
* As far as I can tell IPM is off on our APs.
* The PoE switch they are connected to support 802.3at (and this is detected by the APs)
However the system status output seems to be conflicting on PoE:
Power Status
Item Value
Power Supply : POE-AT
LLDP Power : Successfully negotiated at 25.5W
Current Operational State : USB power disabled; (Overridden by LLDP)
Eth0 HW POE status : POE AF, LLDP power: 25.5W
Eth1 HW POE status : POE AF, LLDP power: 0.0W
As you can see - detected POE-AT, negotiated 25.5W but status POE AF.
