AP-365 Band C
  • 1.  AP-365 Band C
    Posted Oct 12, 2019 06:02 AM
    We are running some AP-365’s outside and when using UNII-3 / Band C channels the max AP TX power is 13dBM I thought that the max EIRP for Band C was 200mW the same as Band A. Am I missing something? We are in the UK. If we can’t go above 13dBM I guess we will use other channels.
  • 2.  RE: AP-365 Band C
    Posted Oct 12, 2019 09:05 AM
    You should use other channels.  The restriction from channels 149 to 165 is similar for all other access points in the GB regulatory domain.
  • 3.  RE: AP-365 Band C
    Posted Oct 13, 2019 05:36 AM
    Thanks Colin for the advice.
    I thought Band A and C had the same EIRP limit of 200mW
  • 4.  RE: AP-365 Band C
    Posted Oct 14, 2019 06:21 AM
    Why are some AP's in the same IAP cluster using channels 161 running at 21dBm?
  • 5.  RE: AP-365 Band C
    Posted Oct 14, 2019 07:35 AM
    What model access points are those?
  • 6.  RE: AP-365 Band C
    Posted Oct 14, 2019 07:40 AM
    They are AP-365's outdoor.
    Strange that one AP on channel 149 will will only run up to 13dBm (the VC) whilst the others will run on 21dBm.
  • 7.  RE: AP-365 Band C
    Posted Oct 14, 2019 07:45 AM
    Do me a favor?  Can you SSH into the VC and type "show drt state" and paste that output into here?
  • 8.  RE: AP-365 Band C
    Posted Oct 14, 2019 07:50 AM
    I have removed the MAC addresses
    swarm drt upgrade status
    Mac IP Address AP Class Status
    xxxxxxxxxxxxxxxxx 10.252.252.111 Ursa drt-ok
    xxxxxxxxxxxxxxxxx 10.252.252.108 Ursa drt-ok
    xxxxxxxxxxxxxxxxx 10.252.252.110 Ursa drt-ok
    xxxxxxxxxxxxxxxxx 10.252.252.103 Ursa drt-ok
    xxxxxxxxxxxxxxxxx 10.252.252.106 Ursa drt-ok
    xxxxxxxxxxxxxxxxx 10.252.252.112 Ursa drt-ok
    xxxxxxxxxxxxxxxxx 10.252.252.113 Hercules drt-ok
    xxxxxxxxxxxxxxxxx 10.252.252.105 Ursa drt-ok
    xxxxxxxxxxxxxxxxx 10.252.252.104 Ursa drt-ok
    xxxxxxxxxxxxxxxxx 10.252.252.107 Ursa drt-ok
    xxxxxxxxxxxxxxxxx 10.252.252.109 Ursa drt-ok
    DRT version :1.0_70671
    DRT build time :May 26,2019
    Default from Image :Yes
    Upgrade in process :No
    Upgrade status :drt ok
    DRT sync in process :No
    Reset in process :No
  • 9.  RE: AP-365 Band C
    Posted Oct 14, 2019 07:54 AM
    One of the AP's is an IAP-315, this is inside, the rest of the AP are outside. The instalaltion type for all of the AP's is default.
  • 10.  RE: AP-365 Band C
    Posted Oct 14, 2019 09:54 AM
    ...and the regulatory domain is GB?
  • 11.  RE: AP-365 Band C
    Posted Oct 14, 2019 11:02 AM
    Yes, Country Code GB.
  • 12.  RE: AP-365 Band C
    Posted Oct 14, 2019 08:15 AM
    The output of show ap debug power-table for the two AP's is below
    Channel 149
    Bandwidth:20Mhz
    Actual Antenna Gain: 4.3
    Connector loss: 0.0
    Effective Antenna Gain: 4.3
    Override board limit: 127.5
    Antenna Polarization: Cross Polarized
    Number of Active Chains 2
    User Configured Power(EIRP, dBm) 15.0
    Min Power(EIRP, dBm) 7.3
    Min Power (Conducted, dBm) 0.0
    Effective User Configured Power (EIRP, dBm) for current active chains 15.0
    Effective User Configured Power (Conducted, dBm) for current active chains 7.7
    Board limits (Conducted, dBm) channel:149
    OFDM:
    48M 24M 12M 6M 54M 36M 18M 9M
    22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0
    HT20:
    NSS, mcs0 mcs1 mcs2 mcs3 mcs4 mcs5 mcs6 mcs7
    NSS1 22.0 22.0 22.0 22.0 22.0 22.0 22.0 21.0
    NSS2 22.0 22.0 22.0 22.0 22.0 22.0 22.0 21.0
    HT40:
    VHT20:
    NSS, mcs0 mcs1 mcs2 mcs3 mcs4 mcs5 mcs6 mcs7 mcs8 mcs9
    NSS1 22.0 22.0 22.0 22.0 22.0 22.0 22.0 21.0 19.0 19.0
    NSS2 22.0 22.0 22.0 22.0 22.0 22.0 22.0 21.0 19.0 19.0
    VHT40:
    VHT80:
    Conducted power limits from the Regulatory table for channel (dBm) 149
    BW-Mod/Phy mode CCK OFDM (V)HT20 (V)HT40 VHT80 VHT160
    #Antenna 1
    #NSS 1
    CDD * 9.0 9.2 8.9 9.0 *
    CDD+CRPOL * 9.0 9.2 8.9 9.0 *
    TXBF * * 9.2 8.9 9.0 *
    TXBF+CRPOL * * 9.2 8.9 9.0 *
    #Antenna 2
    #NSS 1
    CDD * 6.0 6.2 5.9 6.0 *
    CDD+CRPOL * 6.0 6.2 5.9 6.0 *
    TXBF * * 3.7 3.7 3.7 *
    TXBF+CRPOL * * 6.2 5.9 6.0 *
    #NSS 2
    CDD * * 6.2 5.9 6.0 *
    CDD+CRPOL * * 6.2 5.9 6.0 *
    TXBF * * 6.2 5.9 6.0 *
    Combined CONDUCTED Limits(dBm) 149
    #Antenna 1:
    #NSS 1:
    OFDM:
    CDD 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0
    CDD+CRPOL 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0
    TXBF * * * * * * * *
    TXBF+CRPOL * * * * * * * *
    Mode HT/VHT 20:
    CDD 9.2 9.2 9.2 9.2 9.2 9.2 9.2 9.2 9.2 9.2
    CDD+CRPOL 9.2 9.2 9.2 9.2 9.2 9.2 9.2 9.2 9.2 9.2
    TXBF 9.2 9.2 9.2 9.2 9.2 9.2 9.2 9.2 9.2 9.2
    TXBF+CRPOL 9.2 9.2 9.2 9.2 9.2 9.2 9.2 9.2 9.2 9.2
    Mode HT/VHT 40:
    CDD 8.9 8.9 8.9 8.9 8.9 8.9 8.9 8.9 8.9 8.9
    CDD+CRPOL 8.9 8.9 8.9 8.9 8.9 8.9 8.9 8.9 8.9 8.9
    TXBF 8.9 8.9 8.9 8.9 8.9 8.9 8.9 8.9 8.9 8.9
    TXBF+CRPOL 8.9 8.9 8.9 8.9 8.9 8.9 8.9 8.9 8.9 8.9
    Mode HT/VHT 80:
    CDD 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0
    CDD+CRPOL 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0
    TXBF 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0
    TXBF+CRPOL 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0
    #Antenna 2:
    #NSS 1:
    OFDM:
    CDD 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0
    CDD+CRPOL 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0
    Mode HT/VHT 20:
    CDD 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2
    CDD+CRPOL 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2
    TXBF 3.7 3.7 3.7 3.7 3.7 3.7 3.7 3.7 3.7 3.7
    TXBF+CRPOL 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2
    Mode HT/VHT 40:
    CDD 5.9 5.9 5.9 5.9 5.9 5.9 5.9 5.9 5.9 5.9
    CDD+CRPOL 5.9 5.9 5.9 5.9 5.9 5.9 5.9 5.9 5.9 5.9
    TXBF+CRPOL 5.9 5.9 5.9 5.9 5.9 5.9 5.9 5.9 5.9 5.9
    Mode HT/VHT 80:
    CDD 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0
    CDD+CRPOL 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0
    TXBF+CRPOL 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0
    #NSS 2:
    Mode HT/VHT 20:
    TXBF 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2 6.2
    Mode HT/VHT 40:
    TXBF 5.9 5.9 5.9 5.9 5.9 5.9 5.9 5.9 5.9 5.9
    Mode HT/VHT 80:
    TXBF 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0
    Combined EIRP Limits(dBm) 149
    #Antenna 1:
    #NSS 1:
    OFDM:
    CDD 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3
    CDD+CRPOL 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3
    Mode HT/VHT 20:
    CDD 13.5 13.5 13.5 13.5 13.5 13.5 13.5 13.5 13.5 13.5
    CDD+CRPOL 13.5 13.5 13.5 13.5 13.5 13.5 13.5 13.5 13.5 13.5
    TXBF 13.5 13.5 13.5 13.5 13.5 13.5 13.5 13.5 13.5 13.5
    TXBF+CRPOL 13.5 13.5 13.5 13.5 13.5 13.5 13.5 13.5 13.5 13.5
    Mode HT/VHT 40:
    CDD 13.2 13.2 13.2 13.2 13.2 13.2 13.2 13.2 13.2 13.2
    CDD+CRPOL 13.2 13.2 13.2 13.2 13.2 13.2 13.2 13.2 13.2 13.2
    TXBF 13.2 13.2 13.2 13.2 13.2 13.2 13.2 13.2 13.2 13.2
    TXBF+CRPOL 13.2 13.2 13.2 13.2 13.2 13.2 13.2 13.2 13.2 13.2
    Mode HT/VHT 80:
    CDD 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3
    CDD+CRPOL 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3
    TXBF 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3
    TXBF+CRPOL 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3
    #Antenna 2:
    #NSS 1:
    OFDM:
    Mode HT/VHT 20:
    TXBF 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0
    Mode HT/VHT 40:
    Mode HT/VHT 80:
    #NSS 2:
    Mode HT/VHT 20:
    Mode HT/VHT 40:
    Mode HT/VHT 80:
    Note:
    NSS: Number of Spatial Streams
    CDD: Cyclic Diversity Delay
    TXBF: Transmit Beamforming
    MCS: Modulation and Coding Index
    Combined Conducted limits = Min(Board limits, User configured conducted power(floored to min conducted power), override board limit, regulatory limits)
    Combined EIRP Limits = Combined Conducted Limited + Effective Antenna Gain + Power gain + correlation gain
    Effective User Configured Power is minimum of User Configured Power and Flash Eirp Limit floored to Min Power
    Channel 161
    Bandwidth:20Mhz
    Connector loss: 0.0
    User Configured Power(EIRP, dBm) 21.0
    Effective User Configured Power (EIRP, dBm) for current active chains 21.0
    Effective User Configured Power (Conducted, dBm) for current active chains 13.7
    Board limits (Conducted, dBm) channel:161
    OFDM:
    HT20:
    HT40:
    VHT20:
    VHT40:
    VHT80:
    Conducted power limits from the Regulatory table for channel (dBm) 161
    #Antenna 1
    #NSS 1
    CDD * 9.0 9.1 9.0 9.0 *
    CDD+CRPOL * 9.0 9.1 9.0 9.0 *
    TXBF * * 9.1 9.0 9.0 *
    TXBF+CRPOL * * 9.1 9.0 9.0 *
    #Antenna 2
    #NSS 1
    CDD * 6.0 6.1 6.0 6.0 *
    CDD+CRPOL * 6.0 6.1 6.0 6.0 *
    TXBF+CRPOL * * 6.1 6.0 6.0 *
    #NSS 2
    CDD * * 6.1 6.0 6.0 *
    CDD+CRPOL * * 6.1 6.0 6.0 *
    TXBF * * 6.1 6.0 6.0 *
    Combined CONDUCTED Limits(dBm) 161
    #Antenna 1:
    #NSS 1:
    OFDM:
    CDD 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7
    CDD+CRPOL 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7
    Mode HT/VHT 20:
    CDD 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7
    CDD+CRPOL 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7
    TXBF 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7
    TXBF+CRPOL 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7
    Mode HT/VHT 40:
    Mode HT/VHT 80:
    #Antenna 2:
    #NSS 1:
    OFDM:
    CDD 13.7 13.7 13.7 13.7 13.7 13.7 13.7 13.7
    CDD+CRPOL 13.7 13.7 13.7 13.7 13.7 13.7 13.7 13.7
    Mode HT/VHT 20:
    CDD 13.7 13.7 13.7 13.7 13.7 13.7 13.7 13.7 13.7 13.7
    CDD+CRPOL 13.7 13.7 13.7 13.7 13.7 13.7 13.7 13.7 13.7 13.7
    TXBF 13.7 13.7 13.7 13.7 13.7 13.7 13.7 13.7 13.7 13.7
    TXBF+CRPOL 13.7 13.7 13.7 13.7 13.7 13.7 13.7 13.7 13.7 13.7
    Mode HT/VHT 40:
    Mode HT/VHT 80:
    #NSS 2:
    Mode HT/VHT 20:
    Mode HT/VHT 40:
    Mode HT/VHT 80:
    Combined EIRP Limits(dBm) 161
    #Antenna 1:
    #NSS 1:
    OFDM:
    CDD 21.0 21.0 21.0 21.0 21.0 21.0 21.0 21.0
    CDD+CRPOL 21.0 21.0 21.0 21.0 21.0 21.0 21.0 21.0
    Mode HT/VHT 20:
    CDD 21.0 21.0 21.0 21.0 21.0 21.0 21.0 21.0 21.0 21.0
    CDD+CRPOL 21.0 21.0 21.0 21.0 21.0 21.0 21.0 21.0 21.0 21.0
    TXBF 21.0 21.0 21.0 21.0 21.0 21.0 21.0 21.0 21.0 21.0
    TXBF+CRPOL 21.0 21.0 21.0 21.0 21.0 21.0 21.0 21.0 21.0 21.0
    Mode HT/VHT 40:
    Mode HT/VHT 80:
    #Antenna 2:
    #NSS 1:
    OFDM:
    Mode HT/VHT 20:
    TXBF 24.0 24.0 24.0 24.0 24.0 24.0 24.0 24.0 24.0 24.0
    Mode HT/VHT 40:
    Mode HT/VHT 80:
    #NSS 2:
    Mode HT/VHT 20:
    Mode HT/VHT 40:
    Mode HT/VHT 80:
    Note:
