AP-365 not provisioning in Master
  • 1.  AP-365 not provisioning in Master
    Posted Feb 12, 2018 04:02 PM
    AP-365 gets a DHCP address and connects to Master temporarily.  Unable to name AP or add AP to AP Group. Master is a 7240 with 6.5.3.3. Layer 2 switch is a Cisco WS-C3750X-48P with IOS version 12.2(55)SE5. Replaced 365 and cable with the same result. Any ideas would be appreciated.  Thank you.
  • 2.  RE: AP-365 not provisioning in Master
    MVP
    Posted Feb 12, 2018 09:00 PM
    do you have CPSec enabled? Do you have sufficient AP licensing? Is this a brand new AP or was it previously on a controller?
    #AirheadsMobile
  • 3.  RE: AP-365 not provisioning in Master
    Posted Feb 14, 2018 10:49 AM
    do you have CPSec enabled? CPSec not used.  Its not enabled.
    Do you have sufficient AP licensing?   Yes
    Is this a brand new AP or was it previously on a controller?  I've swapped new APs(AP-365_US) 4 times.
    Thank you
