AP-365 - OUTDOOR (REACH)
  • 1.  AP-365 - OUTDOOR (REACH)
    Posted Apr 26, 2018 11:38 AM
    Hello all,
    I am doing a project with mesh, but need to clarify a doubt. I saw in the documentation of the Aruba, the AP-365, when activated for use MESH, can communicate with up to 50 meters. It is true? If I have an AP at one point and another to more than 50 meters, both managed to talk?
  • 2.  RE: AP-365 - OUTDOOR (REACH)
    Posted Apr 26, 2018 12:40 PM
    Yes, 50 meters should be fine between two AP-365s in a mesh deployment. The environment should still be verified to ensure no unexpected obstructions between the APs, and distances great than 50 meters are possible with the correct conditions.
  • 3.  RE: AP-365 - OUTDOOR (REACH)
    Posted Apr 27, 2018 02:27 AM
    I have mesh two AP-365s approx 8m above the ground at 500m without issue.
