Ap-367 speed and distance
  • 1.  Ap-367 speed and distance
    Posted Aug 07, 2019 01:52 AM
    I could not find a document for distance and speed of AP-367. I'm planning for point-to-point between AP-367s. Airspace between them is clear and no tree or building. I'd like to know the speed would I get if the distance is 300 or 500 metres. Thanks.
  • 2.  RE: Ap-367 speed and distance
    Posted Aug 07, 2019 02:10 AM
    you should roughly get about 300Mbps of TCP through put with 80MHz channel width at 500 meter distance
  • 3.  RE: Ap-367 speed and distance
    Posted Aug 07, 2019 02:31 AM
    Much obliged!
