AP 375 Kernel logs in AOS 8.10.0.5
  • 1.  AP 375 Kernel logs in AOS 8.10.0.5
    Posted Mar 15, 2023 11:35 PM
    Hi everyone,
    After upgrading to AOS 8.10.0.5, the outdoor 375 AP has logs:
    KERNEL: [47799.995877] asap_get_cond_limit_160: Secondary channel 48 info not found
    There are a lot of these logs even during working hours or not.
    Anyone else has this log or knows about it?
    Many thanks for your help
  • 2.  RE: AP 375 Kernel logs in AOS 8.10.0.5
    Posted Mar 16, 2023 06:46 AM
    Is that in Instant Mode? Or with a controller?
    What is the channel selected/configured and what channel width?
    What are the configured ARM settings for the channel selection?
    My interpretation of the message is that the AP tries to select a 160MHz channel (which you probably should have disabled, especially outdoor) and can't find a an available 160MHz block around channel 48. I think if you limit the 5GHz radio to 40MHz or 20MHz, the message may be gone.
