AP 387 Mesh Portal / Mesh Point IP Address
  • 1.  AP 387 Mesh Portal / Mesh Point IP Address
    Posted May 31, 2022 08:10 AM
    For these APs, must the IP Address in the same Subnet, not just for management, but for network connectivity too?
    Why?
    I have lost connectivity after changing Address on one site!
    regards, jwh
    Johann Hiller
  • 2.  RE: AP 387 Mesh Portal / Mesh Point IP Address
    Posted Jun 02, 2022 11:25 AM
    Hi Johann,
    if not done so - maybe have a look at this thread: https://community.arubanetworks.com/community-home/digestviewer/viewthread?MID=30325
    For any instant AP it's best practice to have the management subnet as the "untagged vlan" on the switch uplinks and use the "vlan 1" on Instant-AP side as the management vlan (mapped to the untagged-vlan on switch uplink) - of course you cannot add the "vlan 1" on the switch-port as tagged vlan (thus do not use vlan-1 for any user-traffic).
    You can run the IAP-387 in standalone mode and assigne fixed management IP's - but why would there be a need to have the management-IP's of Point and Portal in different subnets ? if you do need to troubleshoot s.th. it's better to have both in the same subnet, so trying a ping from Portal to Point is L2 traffic ...
    Groetjes
    Jochem
    Jochem Knoben
  • 3.  RE: AP 387 Mesh Portal / Mesh Point IP Address
    Posted Jun 02, 2022 01:16 PM
    Thank you very much!
    It was necessary to change IP Addressing for the management VLAN from remote site (Home Office).
    After changing on site user traffic stops!
    I don't really understand why!
    regards, Johann
    Johann Hiller
