Cloud Managed Networks
AP-505 firmware doesn't upgrade via Central
  • 1.  AP-505 firmware doesn't upgrade via Central
    Posted Sep 13, 2021 05:46 AM
    Hello guys,
    I'm trying to update my AP cluster and i get the next error: "Failed in device due to download image fail"
    Here's my show log upgrade
    ----------Download log start----------
    Executing ('/usr/sbin/wget -T 120 -t 3 --no-proxy  --proxy-passwd=****** --no-check-certificate --header="X-Ap-Info:CNLWKPPJ9J,34:8a:12:cd:ef:98,AP-505" -a /tmp/download_url_log http://d2vxf1j0rhr3p0.cloudfront.net/fwfiles/ArubaInstant_Gemini_8.7.1.4_80581'
    fetching ('/usr/sbin/wget -T 120 -t 3 --no-proxy  --proxy-passwd=****** --no-check-certificate --header="X-Ap-Info:CNLWKPPJ9J,34:8a:12:cd:ef:98,AP-505" -a /tmp/download_url_log http://d2vxf1j0rhr3p0.cloudfront.net/fwfiles/ArubaInstant_Gemini_8.7.1.4_80581')
    --16:28:07--  http://d2vxf1j0rhr3p0.cloudfront.net/fwfiles/ArubaInstant_Gemini_8.7.1.4_80581
    => `ArubaInstant_Gemini_8.7.1.4_80581'
    Resolving d2vxf1j0rhr3p0.cloudfront.net... 13.33.93.174, 13.33.93.15, 13.33.93.194, ...
    Connecting to d2vxf1j0rhr3p0.cloudfront.net|13.33.93.174|:80... failed: Connection timed out.
    Connecting to d2vxf1j0rhr3p0.cloudfront.net|13.33.93.15|:80... failed: Connection timed out.
    Connecting to d2vxf1j0rhr3p0.cloudfront.net|13.33.93.194|:80... failed: Connection timed out.
    Connecting to d2vxf1j0rhr3p0.cloudfront.net|13.33.93.164|:80... failed: Connection timed out.
    Retrying.
    --16:36:07--  http://d2vxf1j0rhr3p0.cloudfront.net/fwfiles/ArubaInstant_Gemini_8.7.1.4_80581
    (try: 2) => `ArubaInstant_Gemini_8.7.1.4_80581'
    ----------Download log end------------
    Download status: incomplete
    ----------Upgrade log start----------
    upgrade log not available
    ----------Upgrade log end------------
    Upgrade status: upgrade status not available
    AP-15# ping 8.8.8.8
    Press 'q' to abort.
    PING 8.8.8.8 (8.8.8.8): 56 data bytes
    64 bytes from 8.8.8.8: icmp_seq=0 ttl=110 time=15.8 ms
    64 bytes from 8.8.8.8: icmp_seq=1 ttl=110 time=15.0 ms
    64 bytes from 8.8.8.8: icmp_seq=2 ttl=110 time=15.8 ms
    --- 8.8.8.8 ping statistics ---
    3 packets transmitted, 3 packets received, 0% packet loss
    round-trip min/avg/max = 15.0/15.5/15.8 ms
    Looks like they can't get to those pages.... but the internet seems working well.
    Any ideas?
    Thank you
    octavian romanescu
  • 2.  RE: AP-505 firmware doesn't upgrade via Central
    Posted Sep 13, 2021 05:51 AM
    for firmware upgrade with Aruba Central,  you need to ensure both HTTP and HTTPS is allowed for the IAPs for images.arubanetworks.com
    here are the list of ports that it needs
    https://help.central.arubanetworks.com/2.5.3/documentation/online_help/content/nms/device-mgmt/communication_ports.htm?Highlight=firewall%20ports
