AP-505 syslog - isc_test_check
  • 1.  AP-505 syslog - isc_test_check
    Posted Jul 29, 2021 11:57 AM
    Hi all,
    about two weeks ago i've switched my Unifi APs to Aruba and i'm pretty happy with how everything works right now, especially the IDS/IPS features are a real benefit, though there's still a lot of fine tuning needed. The APs have no internet access.
    Besides sending SNMPv3 traps to a monitoring backend, i also use a central syslog station and here i receive the following message exactly every 5 minutes:
    <WARN> AP: ... <1.2.3.4 00:11:22:33:44:55> isc_test_check: activate access disabled
    CLI shows:
    # sh activate
    IAP MAC Address :00:11:22:33:44:55
    IAP Serial Number :ABCDEFG
    Cloud Activation Key :
    Activate Server :device.arubanetworks.com
    Activate Status :admin-disabled-by-cli
    Provision interval :0 minutes
    The 5 minute interval matches the following lines in the CLI
    AP # sh provision state | include Mins
    Interval of provision rule check (Mins) :5
    Next round of provision remains (Mins) :1
    Max provision interval (Mins) :10080
    When the "Next round of provision remains (Mins)" hits 0, the syslog message above appears
    As this spams my log and also shows up as <WARN>, i wonder if it's sth i have to pay attention to or - if not - how it can be deactivated.
    Mark
    Mark Patruck
  • 2.  RE: AP-505 syslog - isc_test_check
    Posted Jul 30, 2021 05:09 AM
    I don't think this message can be disabled, unless it behaviour has changed in newer firmware. You could check the release notes for newer software version.
    Configuration for SNMP traps is described here. And I don't see an option to filter. There is an option to send the traps as Inform, which may help.
    Aruba Support can probably help you to find if this is considered a bug, which it may be as if the admin deliberately disabled activate, it may not make sense to send traps like these with this priority. Maybe support knows a way to selectively filter the traps.
    Filtering the traps in your SNMP receiver is another option...
  • 3.  RE: AP-505 syslog - isc_test_check
    Posted Jul 30, 2021 06:38 AM
    There is no issue regarding the SNMPv3 Traps...they're working as expected. As you've mentioned, the syslog message shouldn't appear, when 'activation' is disabled, so i'll contact the support.
    FW: ArubaInstant_Gemini_8.8.0.1_80393
    Mark Patruck
  • 4.  RE: AP-505 syslog - isc_test_check
    Posted Aug 26, 2021 01:30 AM
    As Herman already mentioned, you cannot stop the system from printing a "<WARN>: activation is disabled" every 5 minutes. I've discussed this with Aruba Support and it still does not make sense to me, because if i disable an option on purpose as administrator, i know about this and the consequences. Likewise it could print "<WARN>: ntp server disabled", if i didn't use a ntp server.
    However...i'll ignore the message in syslog now. Perhaps it'll change in near future.
    Tests were done with: fw 8.8.0.1/8.7.1.4 and factory defaults to prevent configuration issues.
    Mark Patruck
