AP-505 will not go into discovery mode
  • 1.  AP-505 will not go into discovery mode
    Posted 17 days ago
    I have two AP-505s that I installed at a client last year.  I used the virtual controller to manage both.   I do not recall registering these with Activate or any other Aruba site.  Just recently, the company I work for was aquired by another company who has asked me to put these Arubas on their InstantOn Portal.  I had tried to delete one of the APs on the virtual controller, but the icon was greyed out.  I did the power off reset but it would just reappear in the virtual controller.
    I took the AP home, got it on my PoE switch and did another reset.  I cannot get this AP into discovery mode of the alternate green/amber lights.  During reset, I get red, then amber, then slow flashing green.  After awhile, the system light will be a solid green while the radio light flashes green every 2 seconds.
    I updated the firmware of the AP to 8.12, tried the reset again, but still no dice.  Lights still behave as explained above.  I do not have the console cable to get in.   The AP does grab a IP from DHCP and I can get into the web UI.
    Am I missing something?
  • 2.  RE: AP-505 will not go into discovery mode
    Posted 17 days ago
    Instant and Instant On are two separate products and will not be managed by the Instant On portal.
    Carson Hulcher, ACEX#110
  • 3.  RE: AP-505 will not go into discovery mode
    Posted 16 days ago
    Thank you.  I don't have a lot of experience with Arubas.  I pulled one of the APs down and showed it to my tech and he realized that it wasn't an InstantOn compatible device.
