AP-515: Red Status Light when ipm is disabled
This thread has been viewed 23 times
  • 1.  AP-515: Red Status Light when ipm is disabled
    Posted Apr 25, 2021 11:18 AM
    Following problem occures with AP-515: If ipm is set to disabled, status led will light red. If ipm is enabled, status led turns to green. In both cases wifi works as configured (and expected).
    According to documentation a red status led means: "System error condition - Immediate attention required". Is this an intended behavior or a bug in firmware?
    ***# show version
    ArubaOS (MODEL: 515), Version 8.6.0.2
    Website: http://www.arubanetworks.com
    (c) Copyright 2020 Hewlett Packard Enterprise Development LP.
    Compiled on 2020-01-09 at 08:50:23 UTC (build 73853) by p4build
    FIPS Mode :disabled
    AP uptime is 5 hours 16 minutes 11 seconds
    Reboot Time and Cause: AP rebooted Sun Apr 25 11:56:40 CEST 2021; System cmd at uptime 1D 1H 1M 51S: UI cmd at uptime 1D 1H 1M 44S: reload all
    Christian Felsing
  • 2.  RE: AP-515: Red Status Light when ipm is disabled
    MVP EXPERT
    Posted Apr 25, 2021 01:16 PM
    An AP-515 powered by 802.11af POE can operate in restricted mode but you have to enable IPM.
    Marcel Koedijk | MVP Guru 2021 | ACMP | ACCP | ACDA | Ekahau ECSE | Not an HPE Employee | Opionions are my own
  • 3.  RE: AP-515: Red Status Light when ipm is disabled
    Posted Apr 25, 2021 03:03 PM
    Thank you for hint. External 12V/2A PSU solved problem for now.
    Christian Felsing
