AP-515 with Cisco PoE switch
This thread has been viewed 46 times
  • 1.  AP-515 with Cisco PoE switch
    MVP
    Posted May 30, 2021 07:09 AM
    I have a couple of Aruba 515 IAPs connected to a Cisco 802.3af switch. The AP system LED is giving solid RED light. Also the radios are disabled. I have enabled LLDP in the switch as well as IPM in the AP. But still radios are not coming up. Please see the power status below.
    Power Status
    Item Value
    Power Supply : POE-AF
    LLDP Power : Successfully negotiated at 13.0W
    Current Operational State : 1 ETH port disabled; USB power disabled; All radios disabled
    Eth0 HW POE status : POE AF, LLDP power: 13.0W
    How can I make it work with Cisco 802.3af switches?
    Also I have tried connecting this to a Cisco 802.3at switch with LLDP enabled, but there also the system LED was giving RED light. What am I missing here? My main concern is to make it work with Cisco 802.3at switches.
    Ajin Skariah
  • 2.  RE: AP-515 with Cisco PoE switch
    Posted May 30, 2021 07:23 PM
    you need to enable Intelligent Power mgmt (IPM)
    (Instant AP)(config)# ipm
    (Instant AP)(ipm)# enable
    also note this from the datasheet
  • 3.  RE: AP-515 with Cisco PoE switch
    MVP
    Posted May 30, 2021 11:17 PM
    IPM is already enabled. Still it doesn't work.
    Ajin Skariah
  • 4.  RE: AP-515 with Cisco PoE switch
    Posted May 30, 2021 11:46 PM
    see if you can configure the switch to provide the full class4 PoE (15.4). like providing PoE by watts or class without negotiating.
  • 5.  RE: AP-515 with Cisco PoE switch
    MVP
    Posted May 31, 2021 02:37 AM
    Managed to get it work. Disabled CDP on the port, enabled lldp and IPM on the AP.
    Ajin Skariah
  • 6.  RE: AP-515 with Cisco PoE switch
    Posted May 31, 2021 06:06 AM
    that's great
  • 7.  RE: AP-515 with Cisco PoE switch
    Posted Jun 07, 2021 10:42 AM
    I've found you need to make sure the switch is using  802.3atPoE (aka PoE+). Even if it seems to boot on a lower class of PoE (like 802.3af) the AP won't get all the radios running like they should.
    Especially when using a power injector, use PoE+
    Ambi
    Lawrence Brandt
