AP-515 with IAP-305
  • 1.  AP-515 with IAP-305
    Posted Aug 16, 2019 01:38 PM
    Dear Experts,
    One of the customer is having issues with forming cluster between AP-515 and IAP-305. We have checked the firmware version and IAP-305 is upgraded to match that of 515 but still 515 are not able to join the cluster (IAP-305 is master AP in this case since they were installed first).
    Just want to confirm 515 will join the cluster with previous series am i correct?
  • 2.  RE: AP-515 with IAP-305
    Posted Aug 16, 2019 02:21 PM
    What are the two versions?
  • 3.  RE: AP-515 with IAP-305
    Posted Aug 16, 2019 02:24 PM
    Dear Colin,
    Its 8.4.0.0_68230 for both.
  • 4.  RE: AP-515 with IAP-305
    Posted Aug 16, 2019 02:28 PM
    That should be supported.  You should get a console cable and see why that AP doesn't join.   Make sure the cluster doesn't have auto-join disabled.
  • 5.  RE: AP-515 with IAP-305
    Posted Aug 16, 2019 02:30 PM
    Thanks Colin,
    I will get the APs soon and will check in my lab. Will update this post if anything interesting is observed.
  • 6.  RE: AP-515 with IAP-305
    Posted Aug 16, 2019 04:26 PM
    Not that it should affect this issue, but I would recommend ugrading to the latest 8.5 code (8.5.0.2) which enables some 11ax capabilities on AP-515 and fixes some bugs.
  • 7.  RE: AP-515 with IAP-305
    Posted Aug 17, 2019 02:24 PM
    Thank you Onno, i will check and update
  • 8.  RE: AP-515 with IAP-305
    Posted Aug 18, 2019 03:16 PM
    Dear Experts,
    I think issue is with DRT of 515 which doesnt support PK in 8.4.0.0. How the DRT upgradation process works for the cluster? shall i just upgrade it on Master VC (IAP-305) and the new 515 will upgrade theirs automatically?
