  • 1.  AP-535 compatibility with controller 7205
    Posted May 28, 2024 03:42 AM
    Hello Bro,
                  I am buying a new number of AP-535 to joine the current wi-fi deployment that includes ap-505, AP-305, aruba controller 7205, and aruba OS 8.6.0.21.
    Do this AP-535 with work in this environment with no problems?
  • 2.  RE: AP-535 compatibility with controller 7205
    Posted May 28, 2024 04:57 AM
    Edited by mkk May 28, 2024 04:59 AM
    Hi Mohammed,
    Sure! The AP-535 is supported on your Aruba 7205 controller with this firmware. See datasheets "For unrestricted operation, use 8.6.0.0 or later..
    Keep in mind the max. aminkount is 256 Access Points for a 7205 controller.
    Also required to buy the require" Ld licenses, which are the same licenses as your current access points. (AP Capacity, PEF, RF-Protect, Web-CC, etc.)
    Note that ArubaOS 8.6.x.x is end-of-support since November 2023. I would recommend the latest LSR release what is currently ArubaOS 8.10.0.12.
    See also https://networkingsupport.hpe.com/
    Marcel Koedijk | MVP Expert 2024 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 3.  RE: AP-535 compatibility with controller 7205
    Posted May 28, 2024 05:13 AM
    Thank you so much Bro, I got your point, firstly I will start controller 7205 arubaOS 8.6.0.21 because I still have a few AP-103, and as soon as I retire them I will upgrade to your suggested code ASAP.
    Thank you.
