AP 535 minimum AOS
  • 1.  AP 535 minimum AOS
    Posted Jul 26, 2021 08:25 AM
    We are planning to replace the old 105 APs with some 535 models. Currently, running AOS 8.5.0.10. Is 535 AP supported with AOS 8.5.0.10 or we need to upgrade to a newer version ?
    ioanf
  • 2.  RE: AP 535 minimum AOS
    Posted Jul 26, 2021 09:26 AM
    You can check the data sheet for the AP (link). Under the minimum OS version, you can see the 535 requires 8.5.0.0 or newer, so you should be good and can upgrade further once all APs are replaced.
