AP-565 radios disabled
This thread has been viewed 28 times
  • 1.  AP-565 radios disabled
    Posted Feb 25, 2021 05:46 PM
    Hi
    I like to consult on a problem I have. I have a mixed clusters of AP-500, 505h, 518, 535 and 565. They are on 8.7.1.0 firmware and managed via Aruba Central. The AP-565 were added to the cluster yesterday and it joined the cluster. Unfortunately, they (all of the 565) weren't advertising any SSIDs. When I click on Central under Global > Device > [ap-565-1], it shows both radios as disabled.
    When I go to the AP group > Devices > Access Points > [ap-565-1] > Radio, it shows that both radios are configured to be enabled.
    The APs are connected to Aruba 2930M-SR with 1050W PS.
    === Troubleshooting session started ===
    Output Time: 2021-02-25 22:35:58 UTC
    COMMAND=show ap bss-table
    Aruba AP BSS Table
    bss  ess  port  ip  phy  type  ch/EIRP/max-EIRP  cur-cl  ap name  in-t(s)  tot-t  flags
    Channel followed by "*" indicates channel selected due to unsupported configured channel.
    "Spectrum" followed by "^" indicates Local Spectrum Override in effect.
    Num APs:0
    Num Associations:0
    Flags:       K = 802.11K Enabled; W = 802.11W Enabled; r = 802.11r Enabled; 3 = WPA3 BSS; O = Enhanced-open BSS with transition mode; o = Enhanced-open transition mode open BSS; M = WPA3-SAE mixed mode BSS; E = Enhanced-open BSS without transition mode; m = Agile Multiband (MBO) BSS; c = MBO Cellular Data Capable BSS; I = Imminent VAP Down; T = Individual TWT Enabled; t = Broadcast TWT Enabled; d = Deferred Delete Pending; a = Airslice policy; A = Airslice app monitoring; D = VLAN Discovered;
    COMMAND=show radio config
    2.4 GHz:
    Profile Name:default
    Zone Name:
    Legacy Mode:disable
    Single Chain Legacy:disable
    Beacon Interval:100
    802.11d/802.11h:disable
    Interference Immunity Level:2
    Channel Switch Announcement Count:0
    MAX Distance:0
    Channel Reuse Type:disable
    Channel Reuse Threshold:0
    Background Spectrum Monitor:disable
    Max Tx Power:9
    Min Tx Power:6
    Cell Size Reduction:0
    Smart Antenna:disable
    WIDS Override:off
    40MHZ intolerance:disable
    Honor 40MHZ intolerance:enable
    BSS Color:0
    BSS Color Switch Countdown:10
    Free Channel Index:40
    5.0 GHz:
    Zone Name:
    Very High Throughput:enable
    Legacy Mode:disable
    Beacon Interval:100
    MAX Distance:0
    Standalone Spectrum Band:5ghz-upper
    Max Tx Power:15
    Min Tx Power:12
    WIDS Override:off
    BSS Color:0
    Free Channel Index:25
    Secondary 5.0 GHz:
    Zone Name:
    Legacy Mode:disable
    Beacon Interval:100
    MAX Distance:0
    Max Tx Power:18
    Min Tx Power:12
    WIDS Override:off
    BSS Color:0
    === Troubleshooting session completed ===
    Thanks.
    Simon Lim
  • 2.  RE: AP-565 radios disabled
    Posted Feb 25, 2021 06:36 PM
    I think I may have found the answer. It has to do with the DRT version. It did not have the updated DRT.
    Simon Lim
  • 3.  RE: AP-565 radios disabled
    Posted Aug 10, 2021 11:26 PM
    If the cluster is managed from Central, you won't be able to upgrade the DRT version from Central or WebUI, but I found a way to do it via CLI:
    • Download the DRT file from asp.arubanetworks.com and place it in an FTP/HTTP/TFTP site which is accessible from the APs - in my case I uploaded to the Public Guest files in the ClearPass server :)
    • From the AP acting as VC for the cluster, run the command: upgrade-drt  [URL to DTRT File]  (ftp/http/tftp).
    • Verify DRT upgrade status with: show drt state
      • APs will first download the file
      • Then into upgrade mode
      • Finally into upgraded-done
    This way you don't have to remove the cluster management from Central, and as long as there is server to host the file accessible from the APs it works, the server can be external or internal to your network. ClearPass Guest Public FIles to the rescue ;)
    Max Lopez Perez
