  • 1.  AP-565 version 10.x not using Radio Profile
    Posted Feb 22, 2024 04:12 AM
    Hi all,
    I have a scenario with AP-505 and AP-565 version 10.x Central Managed.
    I use a custom Radio Profile :
    • to limit Bandwith to 20 MHz for 2.4GHz and 5GHz and
    • to limit Channels of 5 GHz only to U-NII1 and U-NII2a : 36,40,44,48,52,56,60
    My issue is :
    • AP-505s work with the correct Bandwidth and channels
    • AP-565s use hiher channels (132, 149, etc ) and 80 MHz bandwith
    Is it the same for you?
  • 2.  RE: AP-565 version 10.x not using Radio Profile
    Posted Feb 22, 2024 06:24 AM
    Try chekcing the wifi specifications section of the datasheet for the 56X series. Also look for recommended best practices for RF.
    /AJ
  • 3.  RE: AP-565 version 10.x not using Radio Profile
    Posted Feb 22, 2024 07:58 AM
    In some parts of the world, the lower channels you configured are unsupported for outdoor use; so the AP-565 cannot use them.
    Here is an overview of allowed channels in different parts of the world.
  • 4.  RE: AP-565 version 10.x not using Radio Profile
    Posted Aug 30, 2024 06:30 AM
    Hi All,
    thank you for your contribution.
    TAC helped me
    I see that AP-565s follows the following channels list
    If you set the AP-565 as indoor it works as AP-505.
    show ap allowed-channels
    Allowed Channels for AP Type 565 Country Code IT
    PHY Type                  Allowed Channels
    2.4GHz (indoor)           1 2 3 4 5 6 7 8 9 10 11 12 13
    5GHz (indoor)             36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
    2.4GHz (outdoor)          1 2 3 4 5 6 7 8 9 10 11 12 13
    5GHz (outdoor)            100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
    2.4GHz 40MHz (indoor)     1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    5GHz 40MHz (indoor)       36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136 149-153 157-161
    2.4GHz 40MHz (outdoor)    1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    5GHz 40MHz (outdoor)      100-104 108-112 116-120 124-128 132-136 149-153 157-161
    5GHz 80MHz (indoor)       36-48 52-64 100-112 116-128 149-161
    5GHz 80MHz (outdoor)      100-112 116-128 149-161
    5GHz 160MHz (indoor)      None
    5GHz 160MHz (outdoor)     None
    5GHz (DFS)                52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
    5GHz (ZWDFS)              disable
