AP-585 LED status
  • 1.  AP-585 LED status
    Posted 28 days ago
    Quick question as the 580 series install guide does not mention this. These new APs provisioned are showing their LED status as green with a quick off every couple of seconds.
    It reminds me of some older APs which would do this if they were connected at 100mb.
    PoE is delivering 45w and ports are properly connecting at 1000mb.
    Any ideas?
  • 2.  RE: AP-585 LED status
    Posted 28 days ago
    AP is operational?  WLAN broadcasting?
    Carson Hulcher, ACEX#110
  • 3.  RE: AP-585 LED status
    Posted 28 days ago
    As noted, this LED indicator isn't documented in the installation guide, I think that will be fixed in the future.
    Green LED with pattern of 2.5 seconds on, 0.5 seconds off, indicates a fault on radio 0.  That may be configuration, DRT, assigned regulatory domain, or failed hardware.
  • 4.  RE: AP-585 LED status
    Posted 28 days ago
    Thank you.
    Right now, I have four in a bench, next to each other as we were testing the configuration and switches feeding them. I'll try powering only one, and if it persists, I'll contact TAC.
