Hi,Guys
Now I have a AP 61 and a two heads special console cable,so how to use this cable to clear the AP pre-confiuration
I dont't know how to enter the proper mode.
Press enter when booting up, until the AP gets to the apboot> prompt.
type "purge"
type "save"
done.
I can't enter the apboot-> enviroment. This is my major problem
What kind of controller is this? Did you purchase a Y-cable or did you make one yourself?
If you have and 800 or 2400 controller, try this method without the cable here: http://kb.arubanetworks.com/cgi-bin/arubanetworks.cfg/php/enduser/std_adp.php?p_faqid=348 (This method wll not work on any other controllers besides the 800 or 2400)
If you made your own cable, please make sure it is constructed using the diagram here: http://community.arubanetworks.com/aruba/attachments/aruba/70/497/2/SOE.jpg
Make sure your terminal settings are: 9600 baud with NO flow Control. Also try to use Putty. Some users have problems breaking into the apboot> if they use hyperterminal or Secure CRT.
Connect the cables as shown in attached picture. Once connected through you terminal window. Press enter to stop boot process. Then purge and save.
