AP 6.2.0.0-3.2.0.4_38110 vulnerability
  • 1.  AP 6.2.0.0-3.2.0.4_38110 vulnerability
    Posted Mar 04, 2014 05:42 AM
    Hello.
    I installed a new set of Aruba 105's at a remote office running Corporate access with Radius Auth and Guest access with password Auth, both on separate non-routed vlans. The Version is 6.2.0.0-3.2.0.4_38110.
    We also have the identical setup at our main office running Version 6.1.3.4-3.1.0.1_35899.
    A pen tester found that if you authenticate to the remote office guest wireless, then revisit the url a few times (https://securelogin.arubanetworks.com/swarm.cgi?opcode=cp_generate&orig_url=687474703a2f2f736c617368646f742e6f72672f).
    The config, including Admin user/password and Radius password are displayed in plain text.
    Then - very scary, if you go to the URL https://securelogin.arubanetworks.com/#home (dispite being on a separarte vlan) you get the contoller home page, which you can log in to with the previously found admin user/pass.
    This was mitigated by simply going to Settings>General>Deny inter user bridging - Enable and Deny local routing - Enable.
    At our main office (Version 6.1.3.4-3.1.0.1_35899) these settings are Disabled, but I am unable to replicate the issue here. So it must be a vulnerability with 6.2.0.0-3.2.0.4_38110.
    Has anyone come across this vulnerability before and know if it is fixed in later versions?
  • 2.  RE: AP 6.2.0.0-3.2.0.4_38110 vulnerability
    Posted Mar 04, 2014 06:22 AM
    You are running very old code.  Please upgrade to the latest, which has the fix.
  • 3.  RE: AP 6.2.0.0-3.2.0.4_38110 vulnerability
    Posted Mar 04, 2014 09:01 AM
    Its not that old, the 105's were purchased a few months ago and shipped with this version. We are running a much older version without this vulnerability. Do you know if this vulnerability is documented anywhere?
    Julian
  • 4.  RE: AP 6.2.0.0-3.2.0.4_38110 vulnerability
    Posted Mar 06, 2014 07:25 AM
    It always be good to go with latest version. You may try the latest and do share here if problem remain the same.
