  • 1.  AP-635 Bootloop
    Posted Sep 26, 2023 08:33 AM
    I purchased a used AP-635 for home lab use purposes.  I am, however stuck in a bootloop and I hope that you may be of assistance.
    Here is the print out when I use the console port to monitor:
    Booting OS partition 1
    Checking image @ 0x3000000
    Copying image from 0x50500000
    Image is signed; verifying checksum... passed
    SHA2 Signature available
    Signer Cert OK
    Policy Cert OK
    RSA signature verified using SHA2.
    Uncompressing Kernel Image ... OK
    [    0.000000]
    [    0.000000] Aruba Networks
    [    0.000000] ArubaOS Version 8.10.0.0-8.10.0.0 (build 83812 / label #83812)
    [    0.000000] Built by jenkins@pr-hpn-cd-build78 on 2022-04-11 at 00:09:35 PDT (gcc version 5.3.0)
    [    0.000000] p:anul_base: 0xb9c00000, v:anul_base: 0xffffffc079c00000, size:0x1800000
    [    1.016545] tpm tpm0: TPM2_RC_INITIALIZE (256) continue selftest
    [    1.737279] tpm tpm0: TPM2 self test passed
    [    2.183182] cnss[27]: INFO: Platform driver probed successfully. plat ffffffc076d18018 tgt 0x1104
    [    2.183613] cnss[2]: INFO: Platform driver probed successfully. plat ffffffc0771b8018 tgt 0xfffd
    [    2.472371] Starting Kernel SHA1 KAT ...
    [    2.472395] Completed Kernel SHA1 KAT
    [    2.506798] Starting Kernel HMAC-SHA1 KAT ...
    [    2.550626] Starting Kernel DES KAT ...
    [    2.603671] Completed Kernel DES KAT
    [    2.651616] Starting Kernel AES KAT ...
    [    2.694318] Completed Kernel AES KAT
    [    2.740134] Starting Kernel AESGCM KAT ...
    [    2.783861] Completed Kernel AESGCM KAT
    [    2.832898] Completed Kernel HMAC-SHA1 KAT
    header read: No such file or directorycheck_rootfs_file failed
    [    2.938799] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
    Connot verify aos_core_rootfs_1.squashfs with sha2-rsa
    [    3.096789] reboot: Restarting system
    APBoot 2.6.2.3 (build 80087)
    Built: 2021-04-29 at 10:04:03
    Model: AP-635
    DRAM:  2 GiB
    Flash: Detected MX25U6435F: total 8 MiB
    MMC:   0 (eMMC)
    PCIE:  link up
    Power: 802.3af POE, port0
    Radio: qcn9072#0, ipq6010#1,ipq6010#2
    Reset: warm
    FIPS:  passed
    // end message
    I am able to get a DHCP IP address, but seems I am not able to find the rootfs file?  Any thoughts on if this is a problem I can solve, or if I should return the AP?
    Thanks for your assistance!
  • 2.  RE: AP-635 Bootloop
    Posted Sep 26, 2023 10:59 AM
    Your best bet may be to contact the seller or TAC for support, as it's possible the AP was incorrectly wiped/reset prior to selling. It could be possible to attempt to load a new image version from the console, however, the boot message you've listed implies that the AP is trying to load a valid image (8.10.0.0) and is unable to access a local filesystem.
    Since this is posted in the controllerless forum, you are attempting to use the AP as a standalone Instant AP rather than paired with a Mobility Controller/Gateway?
  • 3.  RE: AP-635 Bootloop
    Posted Sep 26, 2023 09:21 PM
    That's correct I am using it as an Instant AP.
    I was able to flash a new FW onto the device using tftp which seemed to solve all my issues!  I was not holding my breath given that the 8.10 package loaded looked OK, but as you mentioned it could have been wiped incorrectly.
  • 4.  RE: AP-635 Bootloop
    Posted Jul 22, 2024 03:03 AM
    I am having apparently the same problem, however I am not able to even establish a console connection using the micro USB port to my MacBook.   My mac doesn't see the USB in the /dev folder.   Any suggestions / tips for how to flash the FW using tftp as you mentioned?
  • 5.  RE: AP-635 Bootloop
    Posted Jul 22, 2024 03:08 AM
    Do you have the orange USB to serial console cable?
    JY728A HPE Aruba Networking AP-CBL-SERU Micro-USB TTL3.3V to USB2.0 AP Console Adapter Cable
    There is a warning sign next to the port to not plug a standard micro USB cable as it doesn't work. It's just a micro USB connector, but feeding serial console signals.
  • 6.  RE: AP-635 Bootloop
    Posted Jul 22, 2024 11:34 AM
    I have an HPE orange serial cable on order and am waiting for it to arrive next week.
  • 7.  RE: AP-635 Bootloop
    Posted Jul 31, 2024 08:06 AM
    The HPE orange serial cable helped me connect to the AP and see what was going on during the boot loop.   After several failed attempts to login I was able to successfully factory reset the unit and then enter the default password to get in, and to eventually get to the web interface and upgrade the firmware.
