AP-635, no 6 Ghz led
This thread has been viewed 123 times
  • 1.  AP-635, no 6 Ghz led
    Posted Dec 29, 2021 09:05 AM
    I just got AP-635. Installed it as part of my existing IAP-network. Problem is that 6 GHz led does not come on. 2.4 and 5 GHz leds have light. What setup is needed to get 6 Ghz radio working?
    Ari Kukkonen
  • 2.  RE: AP-635, no 6 Ghz led
    MVP GURU
    Posted Dec 29, 2021 10:53 AM
    Did you check your radio profiles and ARM settings?
    Dustin Burns
    Lead Mobility Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: AP-635, no 6 Ghz led
    Posted Dec 29, 2021 02:25 PM
    What's the configured country of operation? Currently, the AP-635 will enable 6GHz only in a handful of countries. As more become available, this will be enabled through updates of the DRT file.
    Onno Harms
  • 4.  RE: AP-635, no 6 Ghz led
    Posted Dec 29, 2021 02:30 PM
    By DRT version:
    Build 80433: US
    Build 80922:
    UK, Germany
    Build 81497: South Korea
    Build 82129: Peru
    Build 82293: Brazil
    Build 82446: Chile, Cyprus, Czech Republic, Denmark, Estonia, Greece, Iceland, Ireland, Malta, Netherlands, Norway, Slovak Republic, Sweden, Switzerland
    Onno Harms
  • 5.  RE: AP-635, no 6 Ghz led
    Posted Dec 29, 2021 02:57 PM
    ok,
    that is the problem.
    DRT file is missing lot of EU-countries, it should include all of them. Adding Finland would fix my problem. When can you do that, please?
    https://www.wi-fi.org/countries-enabling-wi-fi-6e
    Ari Kukkonen
  • 6.  RE: AP-635, no 6 Ghz led
    Posted Dec 29, 2021 08:25 PM
    We can only add countries that have opened up the band. While the ruling is EU-wide, phasing it in does not happen at the same pace for all countries. When we released our most recent DRT file a couple of weeks ago, 6GHz was not yet open for business in Finland. I'm not sure what the timing is for that to change (should be soon).
    Onno Harms
  • 7.  RE: AP-635, no 6 Ghz led
    Posted Jan 01, 2022 04:27 PM
    ok, I tested and after changing country from FI to SE and installed latest DRT (Check for New Version -button does not retrieve the latest and installing file directly fails on 635, had to install it from webserver), I have now 6 GHz light lit up.
    Ari Kukkonen
  • 8.  RE: AP-635, no 6 Ghz led
    Posted Jan 10, 2022 01:12 PM
    Hi there,
    i have the same issue, no 6GHz is flashing.
    AP-635-RW (8.9.0.0_81161)
    I have installed DRT 1.0_82293
    I have tried the following Country Codes ( SE / GB / DE) but no 6GHz. I tried several channels (5, 21,37,53)
    I tried (indoor / outdoor /standard)
    Any idea what i´m doing wrong?
    Best regards
    Jörg
    Jörg Harth
  • 9.  RE: AP-635, no 6 Ghz led
    Posted Jan 10, 2022 04:04 PM
    Get the latest DRT (82616 at the moment of writing). For many countries, you will need at least DRT version 82446.
  • 10.  RE: AP-635, no 6 Ghz led
    Posted Jan 10, 2022 04:09 PM
    you are not doing anything wrong, you just need newr DRT:
    https://asp.arubanetworks.com/downloads;products=Aruba%20Access%20Points;fileContents=DRT
    Ari Kukkonen
  • 11.  RE: AP-635, no 6 Ghz led
    Posted Jan 14, 2022 05:32 AM
    Hi there,
    i have the accually Version of DRT installed, but no 6GHz WLAN :-(
    Aktuelle Version der DRT (Downloadable Regulatory Table)1.0_82616
    Zone and RF-Zone is DE (Germany)
    AP Config >  Modus for Modul 2 ist access
    Network Config > access for 6GHz Band is on
    Any idea?
    Jörg Harth
  • 12.  RE: AP-635, no 6 Ghz led
    Posted Jan 14, 2022 10:32 AM
    Germany should work with that DRT version for 6GHz. Not sure what you mean by Zone, as that is a feature to enable SSIDs only on specific APs. If you improperly configured that, it may be that the SSID is not enabled on the AP. Your regulatory-domain should be set to the country that you are in.
    You could check the AP log, if there is a reason for the AP to not enable the 6GHz radio. Do you have enough power for the AP? In 802.3af (standard PoE, orange or red status led) the AP may not come up, or have the 6GHz radio disabled.
  • 13.  RE: AP-635, no 6 Ghz led
    Posted Jan 16, 2022 03:33 PM
    do you have WPA3 on? That is mandatory for 6 Ghz.
    Ari Kukkonen
  • 14.  RE: AP-635, no 6 Ghz led
    Posted Jan 17, 2022 03:00 AM
    Thanks Ari, i had WPA2, i didn´t know that WPA3 is mandatory
    Jörg Harth
  • 15.  RE: AP-635, no 6 Ghz led
    Posted Jul 19, 2022 09:11 AM
    Make sure your wireless SSID is using WPA3 encryption and also under setting/miscellaneous -  enable the 6hgz radio.
  • 16.  RE: AP-635, no 6 Ghz led
    Posted Jul 25, 2022 04:19 AM
    and also download latest DRT. My problem was fixed with DRT. I ordered first 635 in June and it was about 10 months later I finally got that 6 Ghz network open for production. Have been changing wifi-chips to AX210 on quite many laptops last couple of months.
