AP-635 Radio Chain configuration
  • 1.  AP-635 Radio Chain configuration
    Posted May 15, 2024 11:29 AM
    I just noticed that my AP-635s are only set to 2x2 Radio.
    Is there an option to change this to 4x4 or is this configuration correct?
     #show ap power-mgmt-statistics ap-name AP_TEST_635
    AP Power Mgmt Status, Last update at 2024-05-15 10:19:24
    LLDP Granted Power        Eth 0: 25.5 Eth 1: 0.0
    LLDP Request Power        Eth 0: 25.5 Eth 1: 25.5
    Power Supply              POE-AT
    USB Status                USB Knob: Auto, USB Status: Enabled
    PSE Status                N.A.
    ETH Status                Eth 0:Enabled. Eth 1:Enabled.
    Radio 5GHz Chain          2*2
    Radio 5GHz Enable         Enabled
    Radio 5GHz Power          Full Power
    Radio 2.4GHz Chain        2*2
    Radio 2.4GHz Enable       Enabled
    Radio 2.4GHz Power        Full Power
    Radio 6GHz Chain          2*2
    Radio 6GHz Enable         Enabled
    Radio 6GHz Power          Full Power
    Second 5GHz Radio Chain   2*2
    Second 5GHz Radio Enable  Enabled
    Second 5GHz Radio Power   Full Power
    CPU Throttle              100%
    Power Consumption         9.7W
    IPM Enable                Enabled
    ITM Status                Not Supported
    Thanks!
  • 2.  RE: AP-635 Radio Chain configuration
    Posted May 15, 2024 11:41 AM
    That output is expected on the AP-635 because the AP-635 is a 2x2 platform. The AP-655 is the 4x4 platform.
