AP- 65 not reporting available UPDATE: it gets more wierd
  • 1.  AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 21, 2012 09:05 AM
    I just got started in aruba so please bear with me.
    I recently go a 2400 controller with AOS v 3.4 installed, I bought an AP-65 access point from ebay, plugged it in, lights came on, but it is not showing on the controller as an available AP to provision.
    I figure this is probably one of a couple issues:
    Incorrect AOS version: Does an AP running a new version of the AOS need an identical or higher version on the controller?  If so, does Aruba have AOS upgrades (the product matrix shows this 2400 is compatible up to V5).  Or is it possible to downgrade the AP?
    Existing Configuration interferes:  I did not see It grab a DHCP address from my server, is it possible the AP was configured with a fixed IP address?
    Bad AP: The lights are on but nobody is home.
    So I figure the only way to really be sure is console access, but I need AC power for that.  What is the volt/amp spec required to power the adapter, and can I plug a regular console cable into the ethernet port once it is powered up?
    Thanks in advance.
    Kory
  • 2.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 21, 2012 10:27 AM
    The AP-65 probably has some fixed configuration since you got it from Ebay and will need to be reset.  Unfortunately, the only way to do this is using the SPOE breakout cable so you can access the serial console.  And as you stated you need a power brick for this.  I believe a 12Vdc / 15W power supply should work for the AP.
    One other option is to capture the traffic on the switch port connecting to the AP65 (will need to configure a SPAN port to capture the traffic and view using Wireshark).  See what IP the AP65 is trying to communicate with and temporarily assign that IP to your Aruba controller.  You should also be able to see what IP is assigned to the AP65 so you can setup routing accordingly.  May have to replicate this in a lab so you don't affect your production network.  A little work but well worth it. :-)  And it's less time if you do not have a SPOE cable and power adapter on hand.
    -Mike
  • 3.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 21, 2012 10:38 AM
    Actually, the 2400 supports SoE on its PoE ports. If you plug the AP65 directly into the controller, you can enable SoE with the telnet soe command. I can't find the exact command to get to the exact port. It might be in the user guide for 3.4.
  • 4.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 21, 2012 11:28 AM
    Here are the instructions on how to do it. It doesn't require the telnet soe command.
    http://kb.arubanetworks.com/cgi-bin/arubanetworks.cfg/php/enduser/std_adp.php?p_faqid=425
  • 5.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 21, 2012 11:34 AM
    Once you get into SoE for the port where you are going to plug in the AP, keep in mind 9600 baud, plug in the AP, hit enter to interrupt the boot (when prompted), run purgeenv and saveenv (saveenv probably not necessary, but it's a habit like always doing a wr mem after entering commands in the cli). Then reboot the AP.
  • 6.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 21, 2012 11:44 AM
    zjennings,
    This is what happens when you get old.  Forget the easier methods. :-)  Thanks for the reminder/tip on using the 2400 to access the APs.
    -Mike
  • 7.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 21, 2012 01:04 PM
    Brilliant,
    Thank you! I am at work right now so I will try it when I get home.
    I didn't think to have wireshark either,
    One more thing, does Aruba use any kind of layer 2 control protocol like Cisco's CDP?  ADP? :smileylol:  (assuming it is enabled on the interface)  it usually includes IP info in the CDP packets, would have been a good way to get the info right from the device.  I didnt see any command that looked like "show cdp neighbors"
    I'll let you know how it goes
  • 8.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 21, 2012 01:07 PM
    Yes, ADP. It is usually enabled by default.
  • 9.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 21, 2012 07:38 PM
    Grrr. it looks like ADP was not availabile in AOS 3.4?
    I can get to the SoE interface but after I launch "connect 1/21" (slot/port number)  It gives me a blank, no acknowlegement that it connected, does not accept commands.  (same response as connecting to an empty port)
  • 10.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 21, 2012 08:23 PM
    Sounds like the wrong baud settings. Did you run the command baud 9600?
    3.4 absolutely has ADP! (Page 77 of the 3.4.2 CRG)
    conf t
    adp discovery enable
    Also, since this is at home, you could log into your router and do up a static dns for aruba-master to point to your 2400.
  • 11.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 22, 2012 08:18 AM
    the 9600 baud rate comes up automatically for the SoE
    soe> connect 1/20
    connect 1/20
    Connecting to 1/20 at 9600 baud 8N1
    Type "~." to disconnect
  • 12.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 22, 2012 08:30 AM
    That is what it should be....  Press enter a couple times.  Is the AP plugged into 1/20?
  • 13.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 22, 2012 09:05 AM
    verified which port its in through show poe (AP) is only PoE device plugged in.
    I can hit enter all day and still nothing.  is the AP no good?
  • 14.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 22, 2012 09:06 AM
    Do you have another AP to try?
  • 15.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Feb 22, 2012 09:11 AM
    I have an RAP-2 that I bought by mistake before I realized it was for remote access only.  Other than that, no, I would need to buy another AP to test whether its the controller or the AP that is shot.
  • 16.  RE: AP- 65 not reporting available UPDATE: it gets more wierd
    Posted Mar 09, 2012 02:45 PM
    I made a console cable and plugged in an external power supply, fired up putty (9600 8-n-1 no flow control)
    this is what I got.
    ±ÕÍatn!é5ÒDªP['HH&&H_¡C!TjEéêm8oem mømåø03
    ÍÍ5R21M!é¢j     5Rþ~åü:   _
                               þz½ÁjRÔ*â*¹ÑÕÉùâo sto|àauto~oot:  B
        0
    Loadiîg FLASHài_Ø0xâfc40000...>îot pråse5Rbõ
    ¥¹BooôZëöJõ
    ...ù.............>........ù...
    Aru¬|Hª×÷K­Í)åÁÉÕÍÿ~¹j¢j21 a¤æL§LN7 PDTà(gcc0ve®®ZË
    Built byâÑÕ¥±                                      Ò¢rJ±Í}ÁÉ}¯¥åõ00RÔüMemory:à25796k/32768o XW¬/[Ø,«BÊʲZ{õrne             ¥Í¥¿¹ÿ¢¥õɹå
    Z+Éj6  õ3,lp=0,pb=>,Vkת-¿V²ÂbzÉ¥ýO¥ùõªþþRÔüLZJ¹¥ÑÉúma ini®¬ËÖ÷
    rPS¢Rª9xY¥ÙùJ¹¥Ñ¥ith r}f­Í¥éõ)jþðxysmap flas
    ¿¥ùÕé²5"¥Í­ÍûâʲZú¥éú¢±½                    VW{_é¢00000 at 1fc00000
    Í}crïni2±
    Í¿ M%ÊbeÍ
             B¢½Á¥(Us_.HSkÖ«VRÔ.­^®Õ
    ÁÁ}±         Ï
    ý¡ï>ýÕ¹âŲ"Ù¥ ßÂÁ in 8-¬Z]±xkK¨8Hµ½2Ý©¥ñÍu Extended Quå~ùàTable ñt 0x0040
    nwmber of CFI chyÍé1
    Pa®®Zëö¢¡
    Éѥѥ½¹N¹½)kþ
    StartZûZɹel S*T¤éPUÉɹ¨µÁ±Ñßɹ±!1 {AT
    µ?ÅÚqrrrÞ¨«±B5
    µ!ÅZýQRjlE ±ßÁZɹ±Â5ý
    ÉÑ¥ÿZɹ¿"MzYrrrÞèë
                      lete| Kerne
                                 TÔ*¤©PU
    StartingZɹ±ESZurrrÞ¨«
                          ±ßñZϹ±
                                 MZQ^ê
    Domain Name'HX®¬,tworksiÖ«»HøNo panic info avaélable
    bondÞ
         ѡɽÍAR2313: 00:ðò:861§OM§|MZÅRôüAP xm| íodelbþrÕµ}Ï
    ¥½ÍBR½¥Íÿº¾JRÔ\Ëë}ýÍ
    p_mod: insW,+WëûKRÔL
    ¥½Ò
    ¹
     ùÑj
    á}ÍÏ¥ÿÂRÔÌ
    ¥o 1: band 0
                ¹Ñj
    ásap_Ïõ}¥¹¥ñé
                 ñ:Iɽñ½col c00a832c
    ú_tarting watchdog prs...¡ø®WËëÖ:ÉÁúÍÁ±¥Ñú¡¥±)jþUSB now prowïséoned
    Getti¹JAá
             ÉÍ͹rrj¤UQQÕQQeAÕQQeAÕQQeAÕQQeÁÕQQeAÝQQåqÕQQeAÕQQeÿ
    I think I managed to get into ap boot mode by pushing enter, because it seemed to allow me to purge and save (both those commands appeared clearly on the screen.
    Is this ap set for a different region? language? or just plain corrupted.
