We happened to have the same issue on a bunch of 655.
apboot> osinfo
Partition 0:
image type: 0
machine type: 71
version: 8.10.0.1-8.10.0.1
build string: ArubaOS version 8.10.0.1-8.10.0.1 for Norma (jenkins@pr-hpn-cd-build78) (gcc version 5.3.0) #84079 SMP Tue May 17 22:14:33 PDT 2022
flags: Instant preserve 0120
oem: aruba
Image is signed; verifying checksum... passed
SHA2 Signature available
Signer Cert OK
Policy Cert OK
RSA signature verified using SHA2.
Partition 1:
image type: 0
machine type: 71
version: 8.10.0.0-8.10.0.0
build string: ArubaOS version 8.10.0.0-8.10.0.0 for Norma (jenkins@pr-hpn-cd-build78) (gcc version 5.3.0) #83812 SMP Mon Apr 11 00:09:35 PDT 2022
oem: aruba
apboot> printenv
autoload=n
autostart=yes
baudrate=9600
boardname=Aultmore
bootargs=console=ttyMSM0,9600n8
bootcmd=boot ap
bootdelay=2
bootfile=arm64emmc.ari
enet1_mode=uplink
fileaddr=50500000
filesize=3d3020
machid=8010012
num_reboot=48
os_partition=1
servername=aruba-conductor
stderr=serial
stdin=serial
stdout=serial
partition 0 was 8.10.0.1, partition 1 was 8.10.0.0 and a boot variable was present to force part 1.
Following commands did the trick.
setenv os_partition 0
save
boot
Thanks for your post, it helped understanding the issue.
Original Message:
Sent: May 05, 2023 08:01 AM
Subject: AP-655 cannot DHCP
I have an AP-655 which is refusing to DHCP.
Console messages on repeat:
Apr 11 00:12:57 udhcpc[11416]: Sending discover...
Apr 11 00:12:59 udhcpc[11416]: send_discover: pkt num 2, secs 47616
Port configuration on the switch seems fine as others APs are able to DHCP and are coming up on the controller.
There is no activity in the DHCP logs at all - not even failed attempts.
The subnet range has plenty of IP leases available.
How can I get around this issue?
