Skip to main content (Press Enter).
Register | Sign in
Skip auxiliary navigation (Press Enter).
Skip main navigation (Press Enter).
Toggle navigation
Discussion
Support
Aruba Documentation Portal
Aruba Support Knowledge Base
Community Learning
News
ACEX Hall of Fame
MVP Overview
Tech Corners
Search
Community Home
Discussion
Topic Thread
Community Home
Discussion
120K
Library
3.2K
Events
0
Members
2.8K
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
AP 655 POE Power Setup
This thread has been viewed 21 times
1.
0
Kudos
Mitchell1
Posted Sep 21, 2022 10:18 PM
Reply Privately
Options Dropdown
Is there a guide on how to setup the Aruba 655 to use both POE ports for power with a Class 4 POE Aruba switch (3810)? The Aruba 655 is connected to mobility controllers using AOS 8.
2.
RE: AP 655 POE Power Setup
0
Kudos
ProbeRequest
Posted Sep 21, 2022 11:03 PM
Reply Privately
Options Dropdown
If you have LLDP enabled on the switch (default) then the power negotiation should occur correctly. You can configure LACP on the switch ports for redundancy. PoE draw should occur automatically.
Aruba Instant: Multiple Ethernet Uplink
ArubaOS: Configuring the AP Wired Port Profile
Original Message
Original Message:
Sent: Sep 21, 2022 10:17 PM
Subject: AP 655 POE Power Setup
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Privacy policy
Terms of service
Site Map
Legal
© Copyright 2024 Hewlett Packard Enterprise Development LP
All Rights Reserved.
Powered by Higher Logic
