AP 70 reset problem
  • 1.  AP 70 reset problem
    Posted Dec 01, 2011 12:19 PM
    Hi.
    Well, I am quite new with Aruba wireless controllers, indeed, its my first experience with wireless networks.
    I have got the administering of Aruba 800 controller. I have this problem with some AP 70:
    In one of our site we had energy problems during the night and some equipment restarted. When the energy came back some AP stopped working (those AP are plugged to a PoE source), at this moment I’m trying to reset them regarding the “Aruba AP 70 Access Point Installation Guide” because the controller lost the connection to those AP (I have the problem with 5 AP´s) and I want to re provision them. I made the serial breakout adapter regarding the manual pinout and I could connect to the AP via serial port but it seems that the AP is not working well, once the AP start booting I can see this message:
    APBoot 1.5.5 (build taylor@harpua-ENG.0000)
    Built: 2006-02-24 18:33:47 (with gcc 3.3.1)
    CPU:   RC32434 MIPS-32 at 266 MHz: 8 kB I-Cache 8 kB D-Cache
    Board: Muscat, Local Bus at 133 MHz
    DRAM:  32 MB
    POST:  passed
    FLASH: 4 MB
    PCI:   scanning bus0 ...
           dev fn venID devID class  rev MBAR0    MBAR1    MBAR2    MBAR3
           0a  00 100b  0020  000002 00  000fff01 07fff000 00000000 00000000
           0b  00 1106  3038  00000c 62  00000000 00000000 00000000 00000000 000ffee1
           0b  01 1106  3038  00000c 62  00000000 00000000 00000000 00000000 000ffec1
           0b  02 1106  3104  00000c 65  07ffef00 00000000 00000000 00000000
           0c  00 168c  0013  000002 01  07fe0000 00000000 00000000 00000000
           0d  00 168c  0013  000002 01  07fd0000 00000000 00000000 00000000
    Net:   en0 en1 br0 lo0
    Bridg: en0 en1
    Hit <Enter> to stop autoboot:  1     I have no response when I press Enter, I tried the same with the 5 AP´s
    DRAM:  32 MB
    POST:  passed
    FLASH: 4 MB
    Bridg: en0 en1
    Hit <Enter> to stop autoboot:  0
    Loading FLASH image @ 0xbfc40000... not present
    Loading FLASH image @ 0xbfc80000...
    Verifying checksum...
    Booting image...
    Aruba Networks
    ArubaOS Version 5.0.3.3 (build 28008 / label #28008)
    Built by p4build@cyprus on 2011-04-21 at 11:18:07 PDT (gcc version 3.4.3)
    BOARD - Muscat
    CPU frequency 266.00 MHz
    Using 133.000 MHz high precision timer. cycles_per_jiffy=266000
    Memory: 25796k/32768k available (1996k kernel code, 6956k reserved, 691k data, 2612k init, 0k highmem)
    available.
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=13573120
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ................................................................................................................................................................................................................
    PCI: Initializing PCI
    wdt: registered with refresh
    RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
    physmap flash device: 400000 at 1fc00000
    AMD Flash AM29LV320D (Top) (Unknown locking)
    phys_mapped_flash: Found 1 x16 devices at 0x0 in 8-bit bank
    Amd/Fujitsu Extended Query Table at 0x0040
    number of CFI chips: 1
    Parsing the partition  info
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: arubanetworks.com
    No panic info available
    <6>eth0: RC32434 Ethernet at 0x18060000, 00:0b:86:c7:9d:9e, Rx IRQ 40, Tx IRQ 41
    natsemi dp8381x driver, version 1.07+LK1.0.17, Sep 27, 2002
    Ethernet port 1 mode: tunnel
    Ethernet Channel Bonding Driver: v3.0.1 (January 9, 2006)
    bonding: bond0: making interface eth0 the new active one.
    bonding: bond0: enslaving eth0 as an active interface with an up link.
    WARNING: eth0 is down; using eth1 for uplink
    bonding: bond0: enslaving eth1 as a backup interface with a down link.
    AP xml model 3, num_radios 2 (jiffies 4831)
    init_asap_mod: installation:0
    radio 0: band 1 ant 2 max_ssid 16
    radio 1: band 0 ant 2 max_ssid 16
    ethernet_device_event: dev eth0 is register
    ethernet_device_event: dev eth0 is up
    asap_gre_init: ADDED GRE protocol c00f132c
    setting bond0 as bridge child
    setting gre0 as split child
    USB not provisioned
    Starting watchdog process...
    Getting an IP address...
    bonding: bond0: link status definitely down for interface eth0, disabling it
    bonding: bond0: now running without any active interface !
    bonding: bond0: link status definitely up for interface eth1.
    bonding: bond0: making interface eth1 the new active one.
    10.30.70.148 255.255.255.0 10.30.70.1
    Running ADP...cat: /tmp/master: No such file or directory
    Done. Master is
    killall: nanny: no process killed
    killall: sapd: no process killed
    Sending SIGKILL to all processes.
    Please stand by while rebooting the system.
    Restarting system.
    The AP does not permit me to hint Enter key to stop the boot process, after that the system just restart once and again and again.
    Is there any problem with the AP? Can I reset by other way?
    Regards.
  • 2.  RE: AP 70 reset problem
    Posted Dec 01, 2011 12:22 PM
    That looks like the AP cannot find the master, and is rebooting as a result.  What are you using for discovery, DNS, DHCP?
    With regards to the "break", you need to make sure you have no flow control on your terminal program.
  • 3.  RE: AP 70 reset problem
    Posted Dec 01, 2011 12:41 PM
    cjoseph: fisrt of all, thanks a lot for your fast response! for discovering I use DHCP when I ping the AP in the controller CLI I reach the AP very well. I can see it active (just with ping) for a couple of seconds an then the AP reboots again. I mean, I discard a network problem. I tryed with every configuration for the terminal program and always I have the same response. Regards.
  • 4.  RE: AP 70 reset problem
    Posted Dec 01, 2011 12:47 PM
    When I say discovery, do you have the "aruba-master" a-record in DNS pointing to the controller IP address?  Do you have the DHCP option 43 and 60 set?
  • 5.  RE: AP 70 reset problem
    Posted Dec 01, 2011 12:59 PM
    cjoseph The controller is not the DHCP server, we have a DC which performs that steps. But I still do not understand, why I have no response from the AP in the console mode?
  • 6.  RE: AP 70 reset problem
    Posted Dec 01, 2011 01:00 PM
    What terminal program are you using?  Again, you need to make sure that flow control is off.
  • 7.  RE: AP 70 reset problem
    Posted Dec 01, 2011 01:29 PM
    I tryed to connect with both putty and MS Hyper Terminal, the only thing that I do not try is to connect the AP directly to one of the controller FE ports and telnet to the AP. I will probe with this option.
  • 8.  RE: AP 70 reset problem
    Posted Dec 01, 2011 01:56 PM
    Puttiy is what you should be using 100%  just make sure flow control is off.
  • 9.  RE: AP 70 reset problem
    Posted Dec 01, 2011 01:58 PM
  • 10.  RE: AP 70 reset problem
    Posted Dec 01, 2011 06:49 PM
    If you made the breakout cable yourself, likely that's the issue.
    Maybe a pin is not terminated or possibly swapped and while you can see the boot sequence, the term is not send the break (return) key stroke.
    If it's doing this for all 5 AP's it's probably the cable.
  • 11.  RE: AP 70 reset problem
    Posted Dec 02, 2011 07:05 AM
    aemory
    maybe you're right, at this moment I'm in doubt with my breakout cable. It seems improbable that the 5 AP´s has the same behaviour. As I said I will connect the AP against the controller and try to telnet it.
    Thanks for the replys to all!!
  • 12.  RE: AP 70 reset problem
    Posted Dec 02, 2011 07:14 AM
    Since you have an 800, use the serial over ethernet method: (the telnet method will not work):  http://kb.arubanetworks.com/cgi-bin/arubanetworks.cfg/php/enduser/std_adp.php?p_faqid=348
    Yes, it says Aruba 2400, but it works on the 800 as well.
