AP 92
  • 1.  AP 92
    Posted Feb 20, 2012 01:25 PM
    I have an AP 92 mounted indoors connected to 2x2 5617 antenna outdoor, should in be able to see a signal (beacon) from the unit even it it does not connect with our remote outdoor AP 175 with 2x2 5010 antenna? I'm using inSSIDer 2.0 to look for the AP.
  • 2.  RE: AP 92
    Posted Feb 20, 2012 02:19 PM
    How are you provisioning the AP-92? Is this a mesh point? I'm confused as to why you mentioned the AP-175, unless you are using the AP-92 as a mesh point/bridge. Is that the case?
  • 3.  RE: AP 92
    Posted Feb 20, 2012 02:46 PM
    The AP 175 is used 2.4g mesh and 5g as the bridge\backhaul to the AP 92 on the building.
  • 4.  RE: AP 92
    Posted Feb 20, 2012 02:49 PM
    Gotcha. Can you do a show ap config ap-name YourAP92Name from the CLI on the controller and post the output?
  • 5.  RE: AP 92
    Posted Feb 20, 2012 03:08 PM
    I will get the info from the IT group that programed the unit and get back, I'm kind of the middle man (electrian that did the install) digging for answer.
    Thanks.
  • 6.  RE: AP 92
    Posted Feb 20, 2012 02:40 PM
    Very interesting.  The AP-92 is a single-radio AP, but the 5617 is a 5ghz antenna.  By default, single radio APs only broadcast and receive on the 2.4ghz network, unless in the AP system profile, you change the band to a.  You could have provisioned this AP and it is currently on the 2.4ghz band, so you will not see anything.  You need to purge it, change the preferred band to A in the AP system profile (only affects singl-radio APs), then reprovision the AP again.
  • 7.  RE: AP 92
    Posted Feb 20, 2012 02:59 PM
    Specs say "Software-configurable single radio capable of supporting 2.4 GHz and 5 GHz"
    Wireless Radio Specifications
    AP type:Single radio, dual-band 802.11n indoor
    Supported Frequency Bands (country-specific restrictions apply):2.400 - 2.4835 GHz           5.150 - 5.250 GHz          5.250 - 5.350 GHz           5.470 - 5.725 GHz                    5.725 - 5.850 GHz
  • 8.  RE: AP 92
    Posted Feb 20, 2012 03:01 PM
    AP type: Single radio, dual-band 802.11n indoor
    Supported Frequency Bands (country-specific restrictions apply): 2.400 - 2.4835 GHz           5.150 - 5.250 GHz          5.250 - 5.350 GHz           5.470 - 5.725 GHz                    5.725 - 5.850 GHz
    Yes, you are correct, but it needs to be configured for the correct band.  From what you mention, you are doing backhaul on the 2.4ghz which is right, but any antenna that starts with a "5" can only transmit on the 5ghz spectrum.  So you have an antenna that will only transmit on 5ghz connected to an AP that is configured to mesh on 2.4ghz.  Are you sure about that antenna part number?
  • 9.  RE: AP 92
    Posted Feb 20, 2012 03:20 PM
    As I said " I'm kind of the middle man (electrician that did the install) digging for answers" I believe the AP are configured correctly by the IT group and are using the 2.4g for local accsess and the 5g for backhaul. I may have my Mesh \Bridge backwards.
  • 10.  RE: AP 92
    Posted Feb 20, 2012 03:34 PM
    Thanks Ken. The important thing to understand here is that the AP-92 can do either 2.4Ghz or 5Ghz. It cannot do both. By default it is 2.4Ghz. There is a setting on the controller as Colin mentioned. If you can get IT to get that output which I requested, we should be able to determine if it is set for 2.4Ghz or 5Ghz.
  • 11.  RE: AP 92
    Posted Feb 20, 2012 04:26 PM
    Thanks, I will get back with that output info. And back to my first question If they are programmed correctly should I be able to see the AP 92 with inSSIDer  if I know its MAC address and it does not have a unique SSID being broadcasted?
  • 12.  RE: AP 92
    Posted Feb 20, 2012 04:29 PM
    Yes, but you would have to be very, very close to the AP, since you might be using the wrong antenna.  Hopefully the AP was even programmed right.  What lights, if any do you see on the AP when it has been up for a few minutes?
  • 13.  RE: AP 92
    Posted Feb 20, 2012 05:12 PM
    Three lights, power - green and steady, Enet - orange and blinking, 11a n - green and steady and 11b g n - off
  • 14.  RE: AP 92
    Posted Feb 20, 2012 05:22 PM
    Is enet blinking because you are using a power injector?
    11a/n means that it is looking to attach on the 5ghz network, so that is good from an antenna perspecitve.
    The big question is did they configure it correctly?  If not, they should be able to see the AP in the controller via Mesh Recovery five minutes after it cannot find a suitable neighbor.
    Please check to see if they can find that AP92 in the controller under Configuration> Wireless> AP Installation
