AP-92 can connect Aruba OS 3.3.2.22 ?
  • 1.  AP-92 can connect Aruba OS 3.3.2.22 ?
    Posted Jan 09, 2014 02:42 AM
    Hi Sir:
             I  have a Aruba Controller 3600 (OS 3.3.2.22 ), my cutomer ask AP-92 use on  3.3.2.22? I do not found Aruba OS mapping AP table.Please support, thank you.
    #3600
  • 2.  RE: AP-92 can connect Aruba OS 3.3.2.22 ?
    Posted Jan 09, 2014 06:48 AM
    Please see the AP Matrix for supported ArubaOS on the current APs (last row on the last page).   It indicates that you need 5.0.4.1, 6.0.2.1, or 6.1.2.0 or higher.   The datasheet states 5.0.4.2; but either way 3.3.2.22 will not work with it.
    http://www.arubanetworks.com/pdf/products/MAT_AP.pdf
  • 3.  RE: AP-92 can connect Aruba OS 3.3.2.22 ?
    Posted Jan 09, 2014 06:49 AM
    Please find here the minimum requirements as what concerns the Aruba OS version:
     Quote from the document : Minimum Software version : ArubaOS 5.0.4.1, 6.0.2.1, 6.1.2.0
