AP-93 mesh and need to use different VLANS
  • 1.  AP-93 mesh and need to use different VLANS
    Posted Jul 26, 2012 03:52 PM
    I have 7 Aruba AP-93 AP's that form a single mesh with no controllers.
    I would like to setup an SSID that will hand out 192.168.100.? to office clients and setup another SSID that will hand out 192.168.220.? to warehouse clients.
    How do I set this up?  Can I do it with my current equipment?
    I have a cisco backbone with the vlans setup and running.
  • 2.  RE: AP-93 mesh and need to use different VLANS
    Posted Jul 26, 2012 04:26 PM
    Are these IAPs or instant APs?  If so, you would just need to trunk the VLAN to each AP and configure each WLAN to trunk to the VLAN you want users on.
  • 3.  RE: AP-93 mesh and need to use different VLANS
    Posted Jul 26, 2012 04:40 PM
    This is my 1st project using Aruba - I think these are instant AP's
  • 4.  RE: AP-93 mesh and need to use different VLANS
    Posted Jul 26, 2012 05:39 PM
    Okay.  Trunk your VLANs to each access point, then create a WLAN referencing each VLAN.
  • 5.  RE: AP-93 mesh and need to use different VLANS
    Posted Jul 27, 2012 09:21 AM
    Thanks for the help so far!  I appreciate that.
    Here is what i tried.
    Took 1 ap-93 and move it to my subnet 220 cisco switch
    The other 6 ap-93 are in the subnet 100 cisco switch
    took interface gi 1/01/ and made it a trunk port on the subnet 220 switch
    plug in an ethernet cable between the trunk port on subnet 220 switch and 1 ap-93 - rebooted ap-93
    Now on the Virtual Controller for the mesh I setup a subnet220 SSID
    Under the SSID subnet 220 under the basic tab I set client IP assignment to default (when that did not work I tried ) vlan ID 220
    The ap is getting 192.168.220.101 from DHCP on the DC put when I connect a client computer to wireless subnet 220 it gets a 169.254.137.217 address
    Am I missing something some setting on the setup of the ap or ssid?
  • 6.  RE: AP-93 mesh and need to use different VLANS
    Posted Jul 27, 2012 09:45 AM
    The "management" VLAN on each IAP needs to be the same.  The trunk ports also need to be the same for all IAPs in the same cluster.  It is understood that the management VLAN is 1.  When you create a WLAN, make sure the VLAN is "network assigned" and corresponds to the VLAN that you want those users on.
    ALL IAPs need to be on the same VLAN to share the same config cluster.
  • 7.  RE: AP-93 mesh and need to use different VLANS
    Posted Jul 27, 2012 12:14 PM
    So if I understand you response - Then I would have one cluster for the 100 subnet and another cluster for the 200 subnet?
    Is that right?
  • 8.  RE: AP-93 mesh and need to use different VLANS
    Posted Jul 27, 2012 02:23 PM
    No.  Sorry.
    Access point management subnet must be the same to be in the same cluster.  As long as you will have all of these access points on the same management subnet you should be fine to manage them centrally.  To each physical access point, you trunk Vlans 100 and 200.  You then create WLANs that send users to those VLANs.
  • 9.  RE: AP-93 mesh and need to use different VLANS
    Posted Aug 06, 2012 12:23 PM
    Does it take a certain software version in order for the AP-93 to connect via trunk port.  IF I take a single cisco 2960 port and make that port a trunk port the AP will come up with 3 green lights (PWR, Ethernet, 11G/B/N) I cannot ping the AP or remote into it.  I've tried setting the IP of the AP via DHCP and/or static.  Now if the port is a regular access port it connects and gets an address from DHCP.
    Here is how the port on the Cisco in configured:
    interface GigabitEthernet1/0/13
     description WIRELESS POE
     switchport trunk native vlan 999
     switchport trunk allowed vlan 100,105,110,220,255,999
     switchport mode trunk
     srr-queue bandwidth share 1 30 35 5
     queue-set 2
     priority-queue out
     mls qos trust cos
     macro description cisco-switch
     auto qos trust
     spanning-tree portfast
     spanning-tree link-type point-to-point
  • 10.  RE: AP-93 mesh and need to use different VLANS
    Posted Aug 07, 2012 05:17 AM
    Make the Native (managment) VLAN of the AP 1
  • 11.  RE: AP-93 mesh and need to use different VLANS
    Posted Aug 07, 2012 08:08 AM
    I did upgrade the IOS software on the AP's to the latest version.  Now I do have trunking options available on the AP's.  I did change this option on the Cisco trunk port that the AP plugs into: switchport trunk native vlan 1
    Did the same on the AP.  3 green lights but AP still does not connect to network.  Cannot ping Cannot web into GUI.  IF I plug it into a regular access port.  I can ping and web into the GUI.  I have rebooted AP and shut/no shut on the Cisco port the AP plugs into.
    Still the ap will not connect if plugged into the trunking port:
    Settings on AP on Wired tab
    Mode: trunk
    native VLAN: 1
    allowed vlans: all
    role:  default_dev_rule
    speed/Duplex: auto
    POE: enabled
    Admin status: up
