AP-93 unable to work on IAP mode
  • 1.  AP-93 unable to work on IAP mode
    Posted Oct 02, 2012 08:28 AM
    We have recently bought a AP-93 Access Point and upgraded it with ArubaInstant_Orion_6.1.3.4-3.1.0.0_35320 firmware.
    The upgrade was successful but now unable to configure it.
    admin/admin doesn't work and the console show this message: "turn off mobility"
    Thanks for your help
  • 2.  RE: AP-93 unable to work on IAP mode
    Posted Oct 02, 2012 08:37 AM
    Did you try the reset button?
  • 3.  RE: AP-93 unable to work on IAP mode
    Posted Oct 02, 2012 09:02 AM
    Please clarify if you purchased an AP-93 or an IAP-93.
    A regular AP-93 cannot be upgraded to become an IAP-93.
    If this is an IAP-93 can you explain your upgrade process?
  • 4.  RE: AP-93 unable to work on IAP mode
    Posted Oct 02, 2012 10:06 AM
    Oh OK! We have purchased an AP-93...
    Thanks for your reply
  • 5.  RE: AP-93 unable to work on IAP mode
    Posted May 13, 2014 03:07 AM
    Hi Same error am using IAP-105... any workaround? its not broadcasting default ssid recolor in both 2.4 & 5 led
    ip_time_handler: Got ip and packets on bond0 Started master election 6-0
    process `snmpd' is using obsolete setsockopt SO_BSDCOMPAT
    asap_send_elected_master: sent successfully
    i am a potential master now
    turn off mobility
  • 6.  RE: AP-93 unable to work on IAP mode
    Posted May 13, 2014 07:37 AM
    have you tried to use a cable?
    set IP adres with console cable and connect with a ethernet cable to go to gui
