Hi all,
If i use ap-93 model AP i must use power injection, is it right ? Or can i use directly ap connected to switch ? Could you give info please ?
Thank You
You can use either a power injector or POE.
Thank You Colin, Must i do any different configuration on switch for connected port for AP ? Thats why i ask ; I tried to directly connect AP to switch but it didn't work later i use power injection AP became up status. What can be cause of that ?
What type of switch is it? Can the switch power other POE devices?
Does the AP93 light up when you plug it into the switch?
