You can do it in AP system profile. Select RF-Band as A instead of G (which is default). This way all your single radio APs will by default come up with 5GHz instead of 2.4.
BTW, AP system profile does under AP-group. So find out which AP-groups are you using and what AP system profiles are being used.
