AP-93H constant reboot
  • 1.  AP-93H constant reboot
    Posted Jul 20, 2012 08:44 AM
    From the console connection to the AP it seems that this is the output before it crashes
    ath_pci: 0.9.4.5 (Atheros/multi-bss)
    PCI: Enabling device 0000:00:00.0 (0000 -> 0002)
    ar7240 data bus error: cause 0x1080001c
    Data bus error, epc == c07855ec, ra == c07855ec
    Oops[#1]:
    I've tried factory_reset, clear, tftpboot, upgrade
    Any other suggestions?
    Full output from access point console connection.......
    Code: 02e02021  0260f809  02c02821 <00551024> 26100001  1454fff5  2404000a  8fbf0034  24020001
    Time Sat Jan  1 00:00:37 2000: Flash erase @ 0xbff70000
    ethsw: no IPv6 routers present
    APBoot 1.2.7.4 (build 32721)
    Built: 2012-03-08 at 11:34:00
    Model: AP-9x
    CPU:   AR7242 revision: 1
    Clock: 390 MHz, DDR rate: 390 MHz, Bus clock: 195 MHz
    DRAM:  64 MB
    POST1: passed
    Copy:  done
    Flash: 16 MB
    *** Warning *** : PCIe WLAN Module not found !!!
    Net:
    Model: AP-9x
    DRAM:  64 MB
    POST1: passed
    Copy:  done
    Flash: 16 MB
    Net:   eth0
    Radio: none
    No radios found
    Hit <Enter> to stop autoboot:  0
    Checking image @ 0xbf100000
    Invalid image format version: 0xffffffff
    Checking image @ 0xbf800000
    Invalid image format version: 0x0
    eth0 down
    DHCP broadcast 1
    eth0 down
    DHCP broadcast 2
    eth0 down
    DHCP broadcast 3
    eth0 down
    DHCP broadcast 4
    eth0 down
    DHCP broadcast 5
    eth0 down
    Retry count exceeded; starting again
    eth0 up: 100 Mb/s full duplex
    DHCP broadcast 1
    DHCP IP address: 172.19.8.154
    DHCP subnet mask: 255.255.0.0
    DHCP def gateway: 172.19.1.254
    DHCP DNS server: 172.19.11.201
    DHCP DNS domain: ad.northcentral.edu
    ADP multicast 1
    Controller address: 172.19.1.38
    Using eth0 device
    TFTP from server 172.19.1.38; our IP address is 172.19.8.154
    Filename 'mips32.ari'.
    Load address: 0x2000000
    Loading: ###########################################################
    done
    Bytes transferred = 3830892 (3a746c hex)
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Automatic boot of image at addr 0x02000000 ...
    ELF file is 32 bit
    Loading .text @ 0x80e00000 (3762024 bytes)
    Loading .data @ 0x81196770 (32 bytes)
    Clearing .bss @ 0x81196790 (16 bytes)
    ## Starting application at 0x80e00000 ...
    Uncompressing...................................
    Aruba Networks
    ArubaOS Version 6.1.3.3 (build 34156 / label #34156)
    Built by p4build@corsica on 2012-06-20 at 08:56:44 PDT (gcc version 4.3.3)
    CPU Rev: 1101
    72x CPU
    Flash variant: 16M
    Cache parity protection disabled
    Using 195.000 MHz high precision timer. cycles_per_jiffy=390000
    Memory: 58008k/65536k available (1850k kernel code, 7464k reserved, 681k data, 2944k init, 0k highmem)
     available.
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=12282368
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ............................................................................................................................................................................................
    Returning IRQ 48
    AR7240 GPIOC major 0
    wdt: registered with refresh
    Enabling Watchdog
    Talisker RSSI LED initialization
    Creating 1 MTD partitions on "ar7240-nor0":
    0x00000000-0x01000000 : "flash"
    i2c /dev entries driver
    i2c-talisker: using default base 0x18040000
    lo: Disabled Privacy Extensions
    IPv6 over IPv4 tunneling driver
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: arubanetworks.com
    AG7240: Length per segment 1536
    AG7240: Max segments per packet 1
    AG7240: Max tx descriptor count    40
    AG7240: Max rx descriptor count    252
    AG7240: fifo cfg 3 01f00140
    AG7240CHH: Mac address for unit 0
    AG7240CHH: 00:1a:1e:10:3f:30
    CFG board AP96
    athrs16_reg_init complete*
    ag7240_ring_alloc Allocated 640 at 0x83aea400
    ag7240_ring_alloc Allocated 4032 at 0x83f72000
    Virian MDC CFG Value ==> 4
    Setting PHY...
    Not enabling interrupts in AR7242 yet...
    ADDRCONF(NETDEV_UP): ethsw: link is not ready
    Ethernet port 1 mode: active-standby
    Ethernet Channel Bonding Driver: v3.0.1 (January 9, 2006)
    ADDRCONF(NETDEV_UP): eth0: link is not ready
    bonding: bond0: enslaving eth0 as a backup interface with a down link.
    ADDRCONF(NETDEV_UP): eth1: link is not ready
    bonding: bond0: enslaving eth1 as a backup interface with a down link.
    AP xml model 55, num_radios 1 (jiffies 5279)
    init_asap_mod: installation:0
    radio 0: band 2 ant 0 max_ssid 16
    ethernet_device_event: dev eth0 is register
    ethernet_device_event: dev eth0 is up
    setting bond0 as bridge child
    setting gre0 as split child
    Starting watchdog process...
    Getting an IP address...
    ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    AG7240: enet unit:0 is up...
    RGMii 1000Mbps full duplex
    AG7240: done cfg2 0x7215 ifctl 0x0 miictrl
    bonding: bond0: link status definitely up for interface eth0.
    bonding: bond0: making interface eth0 the new active one.
    ADDRCONF(NETDEV_CHANGE): ethsw: link becomes ready
    172.19.8.154 255.255.0.0 172.19.1.254
    Running ADP...Done. Master is 172.19.1.38
    ath_hal: module license 'Proprietary' taints kernel.
    ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
    ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
    ath_rate_atheros: Aruba Networks Rate Control Algorithm
    ath_dfs: Version 2.0.0
    Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
    ath_spectrum: Version 2.0.0
    ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
    Oops[#1]:
    Cpu 0
    $ 0   : 00000000 00000000 deadbeef b0007044
    $ 4   : 83dc0000 00007044 0000000f 00000002
    $ 8   : 0000ffff 83dda3da 00000010 00000000
    $12   : 00000000 8109d830 00200200 00000000
    $16   : 00000000 00002710 c078302c c0783018
    $20   : 00000002 0000000f 00007044 83dc0000
    $24   : 00000010 801da480
    $28   : 80614000 80615af8 83d9b1f0 c07855ec
    Hi    : 00000000
    Lo    : 00002710
    epc   : c07855ec ath_hal_wait+0x88/0xf8 [ath_hal]     Tainted: P
    ra    : c07855ec ath_hal_wait+0x88/0xf8 [ath_hal]
    Status: 1000d403    KERNEL EXL IE
    Cause : 1080001c
    PrId  : 00019374
    Modules linked in: ath_pci ath_dev spectrum dfs ath_rate_atheros ath_hal wlan asap_mod drvlog_mod bonding asap_switch ag7240_mod
    Process busybox (pid: 778, threadinfo=80614000, task=83f29028)
    Stack : 8938b000 000000d0 40808000 801daf68 00000000 00000000 83dc0000 c0783000
            00000000 80615bd0 83d9b4a0 80330000 83d9b1f4 c07a50d0 3436d242 000200d0
            00000010 00000000 000186a0 b0000000 00000000 83dc0000 83dc0000 c078d728
            00000020 8109d7a0 000000d0 00000001 00000000 80615bd0 80690000 80129194
            1000d403 83d90280 c05e8a90 83da0000 0000002a 80615bf8 83d9b4a0 c07856bc
    Raw Call Trace:
    [<801daf68>] __bzero+0x4c/0x80
    [<c0783000>] ath_hal_reg_write+0x0/0x18 [ath_hal]
    [<c07a50d0>] ar5416SetResetReg+0xc0/0x144 [ath_hal]
    [<c078d728>] ar5416Attach+0xbc/0xb94 [ath_hal]
    [<80129194>] release_console_sem+0x9c/0x2c8
    [<c07856bc>] ath_hal_attach+0x60/0x174 [ath_hal]
    [<c0783510>] _ath_hal_attach+0x4c/0xcc [ath_hal]
    [<c070c6b0>] bus_read_cachesize+0x30/0x50 [ath_dev]
    [<8016ba8c>] kmem_cache_alloc+0x70/0x94
    [<c06e4c60>] ath_dev_attach+0x180/0x125c [ath_dev]
    [<801e4eac>] __pci_find_next_cap+0x50/0xf8
    [<c05dd7b0>] ath_attach+0x7c/0xa7c [ath_pci]
    [<c05d74d0>] __ath_attach+0x7c/0x3ec [ath_pci]
    [<8016c118>] __kmalloc+0xb8/0xc8
    [<8022a148>] alloc_netdev+0x38/0xd0
    [<c05d9d40>] ath_pci_probe+0x320/0x544 [ath_pci]
    [<80181314>] __lookup_hash+0xe4/0x150
    [<801d55dc>] kobject_get+0x1c/0x30
    [<80200778>] __driver_attach+0x0/0x154
    [<801e6194>] pci_device_probe+0x7c/0xa4
    [<801e5f90>] pci_bus_match+0x18/0x28
    [<802006d8>] driver_probe_device+0x58/0xf8
    [<801afc58>] sysfs_create_dir+0x38/0x8c
    [<802008c4>] __driver_attach+0x14c/0x154
    [<801d59c4>] kobject_add+0x80/0x1c8
    [<801ffec0>] bus_for_each_dev+0x60/0xc8
    [<801ff9c0>] bus_add_driver+0x74/0x168
    [<80129d90>] printk+0x0/0x30
    [<c00000a0>] init_ath_pci+0xa0/0xe0 [ath_pci]
    [<80147dcc>] sys_init_module+0x24c/0x1e14
    [<80159460>] vma_prio_tree_insert+0x28/0x68
    [<8018d984>] touch_atime+0x7c/0xe0
    [<8015f5e8>] vma_link+0x104/0x124
    [<8014c6b8>] generic_file_mmap+0x5c/0x78
    [<801612e4>] do_mmap_pgoff+0x820/0x87c
    [<8012ff4c>] __request_region+0x0/0x154
    [<80112fa4>] stack_done+0x20/0x3c
    Unwound Call Trace:
    [<c07855ec>] ath_hal_wait+0x88/0xf8 [ath_hal]
    ASAP_MOB_SESS_MSG_REQUEST recv-ed:
    ASAP_MOB_SESS_MSG_RESPONSE recv-ed:
  • 2.  RE: AP-93H constant reboot
    Posted Jul 20, 2012 10:13 AM
    Please contact support.  That is typically an RMA.
