AP-93H eth1 - eth4 ports configuration
  • 1.  AP-93H eth1 - eth4 ports configuration
    Posted Nov 04, 2013 05:38 PM
    I am having problems setting up the AP-93H eth1 - eth4 ports.  Does anyone have an example config for using access mode with a different vlan per port?  Are there any common gottcha's?
    Thanks!
    -BIll Davis
  • 2.  RE: AP-93H eth1 - eth4 ports configuration
    Posted Nov 04, 2013 05:50 PM
    Can you please share your config ?
    Make sure that the Wired AP is enabled and that the VLAN you are assigning exist in the controller.
    You can confirm that the link is up by running the following command :
    show  ap debug port status ap-name <ap-name>
    You should also console into the AP to see if there's any errors
