AP 93H not discovered
  • 1.  AP 93H not discovered
    Posted Mar 15, 2014 02:39 PM
    I have a problem with AP 93H not beeing discovered by the controller..
    I am using controller 3600 not sure about the OS version, connecting to the AP using console shows that it is getting an IP address but still not showing on the controller. The controller is working fine as other APs are beeing discovered normally without any issues so I am suspecting that the AP is faulty.
    The following is the last couple of lines from the AP console, not if it is healpful attached aslo test file including more from the console
    Getting an IP address...
    ag7240_ring_alloc Allocated 640 at 0x82d66800
    ag7240_ring_alloc Allocated 4032 at 0x82dad000
    Virian MDC CFG Value ==> 4
    Setting PHY...
    ATHRSF1_PHY: Port 0, Neg Success
    ATHRSF1_PHY: unit 0 phy addr 0 Not enabling interrupts in AR7242 yet...
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    #3600
    Attachment(s)
    txt
    93H.txt   2 KB 1 version
  • 2.  RE: AP 93H not discovered
    Posted Mar 15, 2014 03:12 PM
    The AP93H has a minimum code level of 6.1.3.0 http://www.arubanetworks.com/pdf/products/DS_AP93H.pdf
    You only have 6.1.2.5.  You need to upgrade your controller code.
  • 3.  RE: AP 93H not discovered
    Posted Mar 15, 2014 03:41 PM
    Will upgrade the os and tryb gain, thank you.
