AP-93H Wired Ports
  • 1.  AP-93H Wired Ports
    Posted Aug 24, 2012 02:43 PM
    Do I have to set the VAP profile to "bridged" in order to have the wired ports drop user traffic directly onto the LAN?  Also, we have multiple VLANs, so do I need to define those vlans on the contoller so the AP knows where to direct traffic on the LAN?  Thanks.
  • 2.  RE: AP-93H Wired Ports
    Posted Aug 24, 2012 07:32 PM
    - yes, you do need to define them as bridged
    - You don't necessarily have to define them on the controller, but in the Definition for the Wired AP port profile, you just type in the VLANs that will be allowed, Native VLAN, etc..
  • 3.  RE: AP-93H Wired Ports
    Posted Aug 27, 2012 10:51 AM
    Thanks for the info.
  • 4.  RE: AP-93H Wired Ports
    Posted Aug 27, 2012 10:54 AM
    Wait,
    You do NOT need to define the VAP as bridged to bridge wired traffic.  You ONLY need to define the forwarding mode as "Bridged" in the Wired AP profile.
    Sorry for the misunderstanding.
  • 5.  RE: AP-93H Wired Ports
    Posted Aug 27, 2012 11:23 AM
    OK, that makes a huge difference.  Thanks for clearing that up.
