AP AND Controller in Diff VLAN
  • 1.  AP AND Controller in Diff VLAN
    Posted Aug 31, 2012 07:02 AM
    Hi
    controller is in vlan 100 connected to HP core switch in IDF Side I've a old nortel switch were i couldn't create a native vlan 100 for AP, so i forced to connect AP in vlan 1, now the issue is AP is not provisioning its keep on reloading please find the below AP boot process. in VLAN 1 i've a DHCP server for users and AP is getting an IP address from that server, i've configured master ip address in AP eventhough its not provisioning. L3 is enabled on switch.
    Hope airheads will help!!!!!!!!!!!
    Using eth0 device
    TFTP from server 172.16.0.254; our IP address is 10.5.56.255; sending through ga
    teway 10.5.59.254
    Filename 'mips32.ari'.
    Load address: 0x2000000
    Loading: T T T T T T T T T T
    Retry count exceeded; starting again
    eth0 up: 1 Gb/s full duplex
    ARP Retry count exceeded; starting again
    DHCP broadcast 1
    DHCP IP address: 10.5.56.255
    DHCP subnet mask: 255.255.252.0
    DHCP def gateway: 10.5.59.254
    DHCP DNS server: 0.0.0.0
    DHCP DNS domain:
    Controller address: 172.16.0.254
    Using eth0 device
    teway 10.5.59.254
  • 2.  RE: AP AND Controller in Diff VLAN
    Posted Aug 31, 2012 07:42 AM
    - Make sure no firewall between AP and controller
    - Make sure TFTP are allowed from vlan 1 to vlan 100
    - add "setenv serverip X.X.X.X' on AP (X.X.X.X = controller ip address)
  • 3.  RE: AP AND Controller in Diff VLAN
    Posted Aug 31, 2012 08:39 AM
    Remove the IP from VLAN1.  By default the switches uses the lowest numbered VLAN as the Controller's IP address.  In this case, you left VLAN1, which is the default VLAN at 172.16.0.254, so now when a client finds the controller it will be redirected to that IP.  Remove the ip address from VLAN 1 and it should work:
    config t
    interface vlan 1
    no ip address
    It will ask yo to reboot, but then it will use the next highest numbered VLAN interface as the controller's switch ip.
    Alternatively, you can always hardcode it to a particular vlan with the "controller-ip" command:
    config t
    controller-ip vlan X
