Unlike true RAPs they do not support zero config setup, but if you have console access into the AP, you may be able to fix your problem. What do you think is incorrect?
console in, power up the AP, stop the boot process when the message appears to do so
printenv will show your current settings; check to see if your error is there
setenv <command> will allow you to make changes
save
reset
