AP Boot - Ignoring DHCP
  • 1.  AP Boot - Ignoring DHCP
    Posted Jul 13, 2017 03:37 AM
    Morning all
    Seems our AP's are ignoring option 43 setting in DHCP to find the master controller and choosing current DNS setting for aruba-master. We are sharing equipment between 2 companies one of which uses the DNS for their AP's. I thought with setting DHCP option for the other company AP's we could point the AP's to the other controller, seems not to be the case. AP model is 315.
    Is there a different boot sequence with these?
  • 2.  RE: AP Boot - Ignoring DHCP
    MVP EXPERT
    Posted Jul 13, 2017 03:40 AM
    Hey, did you also configure DHCP Option 60 as well?
    http://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/DHCP_Option_43.php
     The AP boot sequence checks for the DHCP options first, if these are not found it will move on to DNS. Are any other AP's having the same issue?
  • 3.  RE: AP Boot - Ignoring DHCP
    Posted Jul 13, 2017 04:03 AM
    Yes, followed the docs and set option 60 aswell. Actually only tested one AP. But when the guys get in in the US later we can try another.
