ap can not terminate to controller
  • 1.  ap can not terminate to controller
    Posted Dec 16, 2021 11:11 AM
    HI,
    I HAVE 2MM IN HQ
    AND 1 cluster between 2 MC 7005 in HQ
    AND ONE CONTROLLER IN EACH BRANCH
    i have issue in one branch terminated 15 and cannot terminate one more access point to be 16
    model 7005
    mohamed gamal
  • 2.  RE: ap can not terminate to controller
    Posted Dec 16, 2021 12:55 PM
    Type "show log system 50" on both MCs so you can see what the issue is.
  • 3.  RE: ap can not terminate to controller
    Posted Dec 17, 2021 06:56 AM
    Hi, it could be you don't have enough licenses or CPSEC is enabled and the AP has not been whitelisted.
    Hope this helps.
    Ulises Cazares
