AP can't certified to Controller
  • 1.  AP can't certified to Controller
    Posted Dec 26, 2019 10:51 PM
    Hi all,
    My AP can't join Controller. I have to check whitelist-db and see it's certified-hold-factory-cert and they. I manual change state to certified-factory-cert but it's back again to certified-hold-factory-cert
    My AP is 303, Controller 7210, OS 8.3
    command change state
    whitelist-db cpsec modify mac-address xx:xx:xx state certified-factory-cert
  • 2.  RE: AP can't certified to Controller
    Posted Dec 28, 2019 12:36 PM
    Do you have auto-cert provisioning enabled?
    show control-plane-security
  • 3.  RE: AP can't certified to Controller
    Posted Jan 03, 2020 03:25 AM
    I'm disable control-plane-sercurity and it's ok. but my AP can't join to Controller, so i think this is not my problem. i'm just post new thread, pls help
    https://community.arubanetworks.com/t5/Wireless-Access/AP-can-t-provisioning-with-Switch-Cisco-PoE/td-p/629596
  • 4.  RE: AP can't certified to Controller
    Posted Jan 02, 2020 05:25 PM
    The state of a campus AP will be certified-hold-factory-cert when AP is certified with a factory
    certificate but requests to be certified again. Such APs are not
    approved as secure until you manually change the status and verify
    that it is not compromised.
    NOTE: If an AP is in this state due to connectivity problems, then the AP
    recovers and leaves this hold state as soon as connectivity is restored.
    - Check the connection should not be intermittent between the AP and Controller.
    - Try to factory_rest AP.
