We are facing an issue that even TAC engineers are having trouble with it.
We have Mobility controller connected to a CORE switch, the CORE is connected to DHCP server AND Access switch, the access switch connected to APs.
On DHCP, we configured the scope and option 43 is enabled.
but for some reason, not all the APs are coming up, when we console the non working AP, we can see that it's not taking Master-IP and keeps rebooting.
switches have same config on the ports and same VLAN, The working AP will behave normally, while on the same port, the non working AP will as mentioned above keep rebooting and can't find master IP.
anyone faced the same issue?
Attached "NOT working AP Boot.txt" on line 143
Attached "Working AP Boot.txt" on line 103
Eyad Subeh
