AP changing channel/power for a reason
  • 1.  AP changing channel/power for a reason
    Posted Jun 07, 2016 12:43 AM
    Hi Guys,
                i had some complaints about some clients that unable to connect to our WLAN, when i checked one AP i had the below output:
    show ap arm history ap-name AP-19
    Interface :wifi0
    ARM History
    Time of Change Old     Channel New Channel Old Power New Power Reason
    2016-04-21 06:09:42      36+                 153-           24             24                E
    Interface :wifi1
    ARM History
    2016-06-07 04:36:29                         11                1                      24                  24           I
    2016-06-07 04:27:36                          6                11                     24                  24           M
    2016-06-06 23:33:14                           1                6                      24                  24           M
    2016-06-06 06:55:36                           11              1                      24                  24            I
    2016-06-06 06:34:24                             6              11                    24                   24           M
    2016-06-06 03:14:30                            1                6                     24                    24           E
    First : what does the reason tab implies example:
    I : for interference, is it wifi interference or non-wifi interference.
    M: Empty channel, what does that mean?
    E: error threshold exceeded, what does that mean and how to fix or change the value?
    Secondly: how can i go about fixing the problem, change the power values?
    OS: 6.3
    AP: 105
    Thanks for the help,
    farah
  • 2.  RE: AP changing channel/power for a reason
    Posted Jun 07, 2016 03:31 AM
    1.  What regulatory domain is this?
    2.  The power of 24 is too, too high.  The ARM min tx should be 12 and the ARM max should be 18.
    3.  Means that too many frames have been observed with Errors on its current channel, so it is changing.
    4.  M means it saw little traffic on a channel, so it decided to change to it.
    The power should be turned down, period, to start.  See if that makes a difference.
  • 3.  RE: AP changing channel/power for a reason
    Posted Jun 07, 2016 11:54 PM
    Thanks Collins,
                              i have reduced the EIRP and its working fine now.
    Farah
