AP Compatibility
  • 1.  AP Compatibility
    Posted Apr 19, 2018 01:27 PM
    We currently have 10 IAP-135's running 6.4.4.8. I am needig to add two additional AP's to the mesh, can you guys advise what new AP's would be compatible with this setup?
  • 2.  RE: AP Compatibility
    Posted Apr 19, 2018 01:32 PM
    What type of APs are you trying to add?
  • 3.  RE: AP Compatibility
    Posted Apr 19, 2018 01:47 PM
    Looking to add any Instant AP that will conntect to the current setup that still has the 802.11a/b/g/n 2.4, 5 GHz bands and PoE
  • 4.  RE: AP Compatibility
    Posted Apr 20, 2018 04:40 AM
    IAP-205 (or IAP-305) should work. Just make sure that the new APs run the same version of code (so that they can join the cluster) and the VC has the "auto-join" feature enabled
    HTH
  • 5.  RE: AP Compatibility
    Posted Apr 20, 2018 07:47 AM
    Awesome thank you.
  • 6.  RE: AP Compatibility
    Posted Apr 20, 2018 08:07 AM
    You are welcome.
    Furthermore, you can also consider IAP-225 as well since it is the recommended replacement for the IAP-135 (as indicated here: http://www.arubanetworks.com/support-services/end-of-life/)
    HTH
    Kevin
  • 7.  RE: AP Compatibility
    Posted Apr 20, 2018 08:26 AM
    Can you provide the code you are running (entire string)
    Keep in mind that the 305 doesn’t support 6.4.4.8-4.2.x , it requires instantOS 6.5.0.0 and up and the IAP-135 last supported code is -4.2.x
    The 205/225 are EOS
    You can add the IAP325 which can support the 6.4.4.8-4.2.2.x
    Pardon typos sent from Mobile
  • 8.  RE: AP Compatibility
    Posted Apr 20, 2018 08:32 AM
    Hello Victor,
    Full code: 6.4.4.8-4.2.4.9_61734
  • 9.  RE: AP Compatibility
    Posted Apr 20, 2018 08:49 AM
    You can use the IAP-325 , make sure you update the new IAP325 to the version you are currently running before joining the IAP to the existing cluster
  • 10.  RE: AP Compatibility
    Posted Apr 20, 2018 08:57 AM
    Ok thank guys, this helps.
