We have identified an issue that requires us to modify the config of our APs , rather than specify the IP of the master controller, we want the APs set to use ADP. Is there a way to audit all APs at once and see which ones are set with the ip still? Can it be done on the master or in airwave?
We can use the debug cli command, but that to be run per each ap, I'd like to have the data in one place if possible.
