Ap database not sync between master/backup controllers.
  • 1.  Ap database not sync between master/backup controllers.
    Posted Jan 25, 2018 09:11 PM
    TEST
  • 2.  RE: Ap database not sync between master/backup controllers.
    Posted Jan 26, 2018 05:53 AM
    The AP database is not synchronized during database synchronization.  The AP database is created dynamically when APs terminate on that controller.
    There is a different database that is synchronized (WMS).  Type "show wms AP list" on both controllers.
  • 3.  RE: Ap database not sync between master/backup controllers.
    Posted Jan 28, 2018 08:41 PM
    Thanks Colin,
    So if the ap database  is created dynamically when APs terminate on that controller and  i have 30 APs on master controller (26 up, 4 down ), when my master controller is down, i can see only 26 ap with "up" status on backup controller?
    Many thanks for response
  • 4.  RE: Ap database not sync between master/backup controllers.
    Posted Jan 28, 2018 09:24 PM
    The database synchronizes every 30 minutes by default, or manually via the database synchronize command, which should be sufficient.  Any AP that is up on the backup controller will automatically create its statistics and it does not affect any client connectivity.
  • 5.  RE: Ap database not sync between master/backup controllers.
    Posted Jan 28, 2018 09:48 PM
    Hi Colin,
    That's great :D
    Many thanks for clearly explain.
