AP Dirty of No Config When Vlan Hop in Controller
  • 1.  AP Dirty of No Config When Vlan Hop in Controller
    Posted May 27, 2015 06:02 PM
    I thought this one is easy, but after a few hours, I am clueless.
    At small SOHO a 650 version 6.4.2.7 controller was deployed. Controller is the router, dhcp server, three vlans: data, default, and external to the Internet.
    • All ports are trusted
    • “ap wired-ap-profile default” for AP port is trusted
    Problem:
    AP will be “2ID”, no config, if in any vlan different than controller-ip vlan
    (Aruba650) #show vlan
    VLAN CONFIGURATION
    VLAN  Description       Ports                   AAA Profile
    1     Default           GE1/1-4 GE1/6-7 Pc0-7   N/A
    100   DATA              GE1/0                   N/A
    900   OUT_TO_INTERNET   GE1/5                   N/A
    Controller ip is in Vlan 1, if AP in Vlan 100, it will be "2ID"
    (Aruba650) #show datapath session table | include 10.0.1.2
    10.0.1.2        10.0.0.1        17   8209  8209   0/0  0    0   0   tunnel 12   9    0          0          FCI
    10.0.1.2        10.0.0.1        17   8209  8419   0/0  0    0   0   tunnel 12   9    0          0          FYCI
    10.0.1.2        10.0.1.1        17   8209  8209   0/0  0    0   0   1/0         2    0          0          FDYC
    10.0.1.2        10.0.1.1        17   8211  8222   0/0  0    0   0   local       2    0          0          FNYI
    10.0.0.1        10.0.1.2        17   8222  8211   0/0  0    0   0   local       2    0          0          FSCI
    10.0.0.1        10.0.1.2        17   8209  8209   0/0  0    0   1   tunnel 12   9    0          0          FYI
    10.0.0.1        10.0.1.2        17   8419  8209   0/0  0    0   1   tunnel 12   9    0          0          FYI
    10.0.1.2        10.0.0.1        17   4500  4500   0/0  0    0   0   1/0         2    0          0          FC
    10.0.0.1        10.0.1.2        17   4500  4500   0/0  0    0   0   1/0         2    0          0          FY
    10.0.1.2        10.0.0.1        47   0     0      0/0  0    40  0   1/0         4fc  0          0          FC
    10.0.0.1        10.0.1.2        47   0     0      0/0  0    0   0   1/0         4fc  0          0          F
    Datapath of AP while Dirty
    Best Regards,
  • 2.  RE: AP Dirty of No Config When Vlan Hop in Controller
    Posted May 27, 2015 06:26 PM
    Can you do a show ip interface brief and make sure the interface is up / up
  • 3.  RE: AP Dirty of No Config When Vlan Hop in Controller
    Posted May 28, 2015 09:09 AM
    Yes, all vlans are up/up
    (Aruba650) #show ip interface brief
    Interface                   IP Address / IP Netmask        Admin   Protocol
    vlan 1                        10.0.0.1 / 255.255.255.0     up      up
    vlan 900                 x.x.x.x / 255.255.255.0     up      up
    vlan 100                      10.0.1.1 / 255.255.255.0     up      up
    loopback                    unassigned / unassigned        up      up
    mgmt                        unassigned / unassigned        down    down
    (Aruba650) #show ap database
    AP Database
    Name               Group    AP Type  IP Address  Status         Flags  Switch IP                                                Standby IP
    d8:c7:c8:c2:50:4c  default  105      10.0.1.2    Up 15h:28m:7s  2ID    10.0.0.1                                                 0.0.0.0
  • 4.  RE: AP Dirty of No Config When Vlan Hop in Controller
    Posted May 28, 2015 09:14 AM
    You could be blocking GRE traffic from the subnet that the access point is on.
  • 5.  RE: AP Dirty of No Config When Vlan Hop in Controller
    Posted May 28, 2015 09:53 AM
    This 650 controller was “write erase all” to manufacture default, reinstalled licenses which include APs, PoE, RFP and NG-PEF.
    At current, the controller configured with three vlans, dhcp server, and nothing else. So by default it seems like the controller blocks GRE between two subnets within itself.
    I am looking for a way to remove this block.
    Port mirror traffic shows GRE between AP and controller:
  • 6.  RE: AP Dirty of No Config When Vlan Hop in Controller
    Posted May 28, 2015 09:55 AM
    I would type "show datapath session table <ip address of access point>" to see if any traffic is being denied.
    I don't know what your configuration is, so we have to go through this step by step.
  • 7.  RE: AP Dirty of No Config When Vlan Hop in Controller
    Posted May 28, 2015 10:28 AM
    Thanks Colin.  as I stated earlier, the configuration is all controller default
    Datapath show only one deny from AP to its gateway, which is also at the controller.
    AP ip address: 10.0.1.2/24
    Gateway of the subnet that AP resides on: 10.0.1.1/24
    Controller ip address: 10.0.0.1/24
  • 8.  RE: AP Dirty of No Config When Vlan Hop in Controller
    Posted May 28, 2015 10:30 AM
    Please open a tac case.  I am only guessing based on what you are telling me, so there could be something hidden that is preventing your access point from connecting successfully.
  • 9.  RE: AP Dirty of No Config When Vlan Hop in Controller
    Posted May 28, 2015 01:53 PM
    Case opened.  I'll update the result.
  • 10.  RE: AP Dirty of No Config When Vlan Hop in Controller
    Posted May 28, 2015 04:22 PM
    Problem SOLVED!!!
    AP does not like NAT.  Removed "ip nat inside" from the vlan interface of the controller solved my problem.
    Credit and kudos to TAC.
