And, here is my ARM profile. Thank you.
(Aruba7205) #show rf arm-profile wh-arm
Adaptive Radio Management (ARM) profile "wh-arm"
Parameter Value
Assignment single-band
Allowed bands for 40MHz channels a-only
80MHz support Enabled
160MHz-support None
Client Aware Enabled
Max Tx EIRP 33 dBm
Min Tx EIRP 21 dBm
Rogue AP Aware Disabled
Scan Interval 10 sec
Aggressive scanning true
Active Scan Disabled
ARM Over the Air Updates Enabled
Scanning Enabled
Multi Band Scan Enabled
VoIP Aware Scan Disabled
Power Save Aware Scan Disabled
Video Aware Scan Disabled
Ideal Coverage Index 10
Acceptable Coverage Index 4
Free Channel Index 25
Interfering AP Weight 25 %
Backoff Time 240 sec
Error Rate Threshold 70 %
Error Rate Wait Time 90 sec
Channel Quality Aware Arm Disabled
Channel Quality Threshold 60 %
Channel Quality Wait Time 120 sec
Minimum Scan Time 8
Load aware Scan Threshold 1250000 Bps
Mode Aware Arm Disabled
Scan Mode all-reg-domain
Client Match Enabled
Client Match Report Interval (sec) 30
Allows Client Match to Automatically Clear Unsteerable Clients after Ageout Enabled
Client Match Unsteerable Client Ageout Interval 2 Days 0 Hours
Client Match Band Steering G Max Signal (-dBm) 45
Client Match Band Steering A Min Signal (-dBm) 75
Client Match Sticky Client Check Interval (sec) 3
Client Match Sticky Client SNR (dB) 18
Client Match SNR Delta Bound(dB) 10
Client Match Sticky Min Signal 65
Client Match Steering Timeout (sec) 10
Client Match Load Balancing Threshold (%) 20
Client Match IOS Steering Backoff Interval (sec) 300
Client Match VBR Stale Entry Age (sec) 120
Client Match Max Steering Failures 2
Client Match Load Balancing Client Threshold 30
Client Match Load Balancing SNR Threshold (dB) 30
Client Match Load Balancing Signal Delta Bound (dB) 5
Client Match 802.11v BSS Transition Management Enabled
Dynamic Bandwidth Switch Disabled
Dynamic Bandwidth Switch Wait Time (sec) 30
Dynamic Bandwidth Switch Triggering Indicator CCA ibss Threshold (%) 10
Dynamic Bandwidth Switch Triggering Indicator Beacon Failed Threshold 30
Dynamic Bandwidth Switch Triggering Indicator CCA intf Threshold (%) 30
Dynamic Bandwidth Switch Clear Time (min) 30
Client Match MU Client threshold 15
Client Match MU SNR threshold (dB) 30
Elan Cao
Original Message:
Sent: Jan 18, 2021 05:01 AM
Subject: AP disappears and appears always
Dears,
I've noticed recently that one AP is always disappear and appear in the controller (Also it's SSID disappears and appears), but the uptime is still going, so surely it did not reboot.
I check the log, many thing like :VAP device aruba101 created osifp and ARM Empty Channel Trigger new , what does it mean?
(Aruba7205) #show log all | include 1F-2Jan 14 17:43:59 authmgr[4129]: <132093> <4129> <ERRS> |authmgr| WPA2 Key message 4 from Station 5c:ea:1d:2d:41:0b 24:f2:7f:2f:43:c0 1F-2 did not match the replay counter 02 vs 03Jan 18 07:44:10 sapd[976]: <404070> <WARN> |AP 1F-2@172.27.43.2 sapd| AM 24:f2:7f:2f:43:c0: ARM Empty Channel Trigger new 11-0/0 old 1-202/0 new_rra 11/7Jan 18 10:12:08 sapd[976]: <404070> <WARN> |AP 1F-2@172.27.43.2 sapd| AM 24:f2:7f:2f:43:c0: ARM Empty Channel Trigger new 1-0/0 old 11-157/0 new_rra 1/7Jan 18 10:45:16 sapd[976]: <404070> <WARN> |AP 1F-2@172.27.43.2 sapd| AM 24:f2:7f:2f:43:c0: ARM Empty Channel Trigger new 11-0/0 old 1-167/0 new_rra 11/7Jan 18 11:00:50 sapd[976]: <404070> <WARN> |AP 1F-2@172.27.43.2 sapd| AM 24:f2:7f:2f:43:c0: ARM Empty Channel Trigger new 1-0/0 old 11-155/0 new_rra 1/7Jan 18 11:07:52 sapd[976]: <404070> <WARN> |AP 1F-2@172.27.43.2 sapd| AM 24:f2:7f:2f:43:c0: ARM Empty Channel Trigger new 11-0/0 old 1-162/0 new_rra 11/7Jan 18 11:41:12 sapd[976]: <404070> <WARN> |AP 1F-2@172.27.43.2 sapd| AM 24:f2:7f:2f:43:c0: ARM Empty Channel Trigger new 1-0/0 old 11-158/0 new_rra 1/7Jan 18 12:25:24 sapd[976]: <404070> <WARN> |AP 1F-2@172.27.43.2 sapd| AM 24:f2:7f:2f:43:c0: ARM Empty Channel Trigger new 11-0/0 old 1-34/0 new_rra 11/7Jan 18 13:37:25 sapd[976]: <404070> <WARN> |AP 1F-2@172.27.43.2 sapd| AM 24:f2:7f:2f:43:c0: ARM Empty Channel Trigger new 1-0/0 old 11-214/0 new_rra 1/7Jan 18 14:08:34 sapd[976]: <404070> <WARN> |AP 1F-2@172.27.43.2 sapd| AM 24:f2:7f:2f:43:c0: ARM Empty Channel Trigger new 11-0/0 old 1-146/0 new_rra 11/7Jan 18 14:58:32 sapd[976]: <404070> <WARN> |AP 1F-2@172.27.43.2 sapd| AM 24:f2:7f:2f:43:c0: ARM Empty Channel Trigger new 1-0/0 old 11-170/0 new_rra 1/7Jan 18 15:55:50 KERNEL(1F-2@172.27.43.2): [245435.642293] VAP device aruba100 created osifp: (d95e35c0) os_if: (d72a0000)Jan 18 15:55:50 KERNEL(1F-2@172.27.43.2): [245435.700874] VAP device aruba101 created osifp: (d95e75c0) os_if: (d9348000)Jan 18 15:55:50 KERNEL(1F-2@172.27.43.2): [245435.758516] VAP device aruba102 created osifp: (d95e05c0) os_if: (d68e8000)Jan 18 15:59:28 KERNEL(1F-2@172.27.43.2): [245653.897844] VAP device aruba100 created osifp: (dbd965c0) os_if: (d60d8000)Jan 18 15:59:28 KERNEL(1F-2@172.27.43.2): [245653.956765] VAP device aruba101 created osifp: (dbd945c0) os_if: (d9720000)Jan 18 15:59:28 KERNEL(1F-2@172.27.43.2): [245654.014435] VAP device aruba102 created osifp: (dbd915c0) os_if: (dd4c8000)Jan 18 16:03:16 KERNEL(1F-2@172.27.43.2): [245881.963540] VAP device aruba100 created osifp: (d95e35c0) os_if: (dbc70000)Jan 18 16:03:16 KERNEL(1F-2@172.27.43.2): [245882.022843] VAP device aruba101 created osifp: (d95e05c0) os_if: (d6b38000)Jan 18 16:03:16 KERNEL(1F-2@172.27.43.2): [245882.080127] VAP device aruba102 created osifp: (d95e75c0) os_if: (d77b8000)Jan 18 16:08:00 KERNEL(1F-2@172.27.43.2): [246165.861528] VAP device aruba100 created osifp: (dbd915c0) os_if: (dbc70000)Jan 18 16:08:00 KERNEL(1F-2@172.27.43.2): [246165.920695] VAP device aruba101 created osifp: (dbd925c0) os_if: (d6110000)Jan 18 16:08:00 KERNEL(1F-2@172.27.43.2): [246165.978141] VAP device aruba102 created osifp: (dbd955c0) os_if: (d9248000)Jan 18 16:10:08 KERNEL(1F-2@172.27.43.2): [246293.286034] VAP device aruba100 created osifp: (d95e15c0) os_if: (dd500000)Jan 18 16:10:08 KERNEL(1F-2@172.27.43.2): [246293.344846] VAP device aruba101 created osifp: (d95e75c0) os_if: (d8248000)Jan 18 16:10:08 KERNEL(1F-2@172.27.43.2): [246293.402122] VAP device aruba102 created osifp: (d95e25c0) os_if: (d8518000)Jan 18 16:11:47 KERNEL(1F-2@172.27.43.2): [246392.571553] VAP device aruba100 created osifp: (dbd925c0) os_if: (d6118000)Jan 18 16:11:47 KERNEL(1F-2@172.27.43.2): [246392.630620] VAP device aruba101 created osifp: (dbd965c0) os_if: (d7a98000)Jan 18 16:11:47 KERNEL(1F-2@172.27.43.2): [246392.688168] VAP device aruba102 created osifp: (dbd915c0) os_if: (dd200000)Jan 18 16:14:53 KERNEL(1F-2@172.27.43.2): [246578.645886] VAP device aruba100 created osifp: (d95e55c0) os_if: (d7218000)Jan 18 16:14:53 KERNEL(1F-2@172.27.43.2): [246578.704783] VAP device aruba101 created osifp: (d95e05c0) os_if: (d7638000)Jan 18 16:14:53 KERNEL(1F-2@172.27.43.2): [246578.762414] VAP device aruba102 created osifp: (d95e45c0) os_if: (d7ee0000)Jan 18 16:17:23 KERNEL(1F-2@172.27.43.2): [246729.164149] VAP device aruba100 created osifp: (dbd965c0) os_if: (d9e48000)Jan 18 16:17:24 KERNEL(1F-2@172.27.43.2): [246729.223315] VAP device aruba101 created osifp: (dbd935c0) os_if: (d6170000)Jan 18 16:17:24 KERNEL(1F-2@172.27.43.2): [246729.280140] VAP device aruba102 created osifp: (dbd975c0) os_if: (d8f60000)Jan 18 16:23:55 KERNEL(1F-2@172.27.43.2): [247120.353360] VAP device aruba100 created osifp: (d95e35c0) os_if: (d97d8000)Jan 18 16:23:55 KERNEL(1F-2@172.27.43.2): [247120.412660] VAP device aruba101 created osifp: (d95e75c0) os_if: (dc9c0000)Jan 18 16:23:55 KERNEL(1F-2@172.27.43.2): [247120.470147] VAP device aruba102 created osifp: (d95e45c0) os_if: (da550000)Jan 18 16:25:08 KERNEL(1F-2@172.27.43.2): [247194.002365] VAP device aruba100 created osifp: (dbd905c0) os_if: (d9a00000)Jan 18 16:25:08 KERNEL(1F-2@172.27.43.2): [247194.060818] VAP device aruba101 created osifp: (dbd975c0) os_if: (d7f08000)Jan 18 16:25:08 KERNEL(1F-2@172.27.43.2): [247194.118123] VAP device aruba102 created osifp: (dbd955c0) os_if: (d7f80000)Jan 18 16:26:58 KERNEL(1F-2@172.27.43.2): [247303.469954] VAP device aruba100 created osifp: (d95e35c0) os_if: (d6cc8000)Jan 18 16:26:58 KERNEL(1F-2@172.27.43.2): [247303.528654] VAP device aruba101 created osifp: (d95e25c0) os_if: (db9f8000)Jan 18 16:26:58 KERNEL(1F-2@172.27.43.2): [247303.586120] VAP device aruba102 created osifp: (d95e75c0) os_if: (d76b8000)Jan 18 16:28:52 KERNEL(1F-2@172.27.43.2): [247417.213902] VAP device aruba100 created osifp: (dbd955c0) os_if: (d92b0000)Jan 18 16:28:52 KERNEL(1F-2@172.27.43.2): [247417.272773] VAP device aruba101 created osifp: (dbd935c0) os_if: (d8578000)Jan 18 16:28:52 KERNEL(1F-2@172.27.43.2): [247417.330141] VAP device aruba102 created osifp: (dbd945c0) os_if: (d8d20000)Jan 18 16:29:48 KERNEL(1F-2@172.27.43.2): [247473.891130] VAP device aruba100 created osifp: (d95e05c0) os_if: (d9cb0000)Jan 18 16:29:48 KERNEL(1F-2@172.27.43.2): [247473.948694] VAP device aruba101 created osifp: (d95e75c0) os_if: (d9bc8000)Jan 18 16:29:48 KERNEL(1F-2@172.27.43.2): [247474.006095] VAP device aruba102 created osifp: (d95e45c0) os_if: (d7970000)Jan 18 16:33:22 sapd[976]: <404070> <WARN> |AP 1F-2@172.27.43.2 sapd| AM 24:f2:7f:2f:43:c0: ARM Empty Channel Trigger new 11-0/0 old 1-150/0 new_rra 11/7Jan 18 16:37:40 KERNEL(1F-2@172.27.43.2): [247945.732060] VAP device aruba100 created osifp: (dbd945c0) os_if: (d9ad0000)Jan 18 16:37:40 KERNEL(1F-2@172.27.43.2): [247945.790841] VAP device aruba101 created osifp: (dbd965c0) os_if: (d9c28000)Jan 18 16:37:40 KERNEL(1F-2@172.27.43.2): [247945.848073] VAP device aruba102 created osifp: (dbd925c0) os_if: (d9108000)Jan 18 16:42:50 KERNEL(1F-2@172.27.43.2): [248255.587304] VAP device aruba100 created osifp: (d95e65c0) os_if: (d9bb0000)Jan 18 16:42:50 KERNEL(1F-2@172.27.43.2): [248255.646716] VAP device aruba101 created osifp: (d95e45c0) os_if: (d8068000)Jan 18 16:42:50 KERNEL(1F-2@172.27.43.2): [248255.704079] VAP device aruba102 created osifp: (d95e25c0) os_if: (d6a70000)Jan 18 16:44:02 KERNEL(1F-2@172.27.43.2): [248327.554158] VAP device aruba100 created osifp: (dbd955c0) os_if: (d9ba0000)Jan 18 16:44:02 KERNEL(1F-2@172.27.43.2): [248327.612696] VAP device aruba101 created osifp: (dbd905c0) os_if: (d8f58000)Jan 18 16:44:02 KERNEL(1F-2@172.27.43.2): [248327.670131] VAP device aruba102 created osifp: (dbd975c0) os_if: (d6630000)Jan 18 16:46:37 KERNEL(1F-2@172.27.43.2): [248482.860296] VAP device aruba100 created osifp: (d95e15c0) os_if: (d6568000)Jan 18 16:46:37 KERNEL(1F-2@172.27.43.2): [248482.918624] VAP device aruba101 created osifp: (d95e25c0) os_if: (d8810000)Jan 18 16:46:37 KERNEL(1F-2@172.27.43.2): [248482.976318] VAP device aruba102 created osifp: (d95e75c0) os_if: (da480000)Jan 18 16:47:45 KERNEL(1F-2@172.27.43.2): [248550.726065] VAP device aruba100 created osifp: (dbd905c0) os_if: (d71f8000)Jan 18 16:47:45 KERNEL(1F-2@172.27.43.2): [248550.784571] VAP device aruba101 created osifp: (dbd925c0) os_if: (d75e8000)Jan 18 16:47:45 KERNEL(1F-2@172.27.43.2): [248550.842072] VAP device aruba102 created osifp: (dbd935c0) os_if: (d76a8000)Jan 18 16:48:40 KERNEL(1F-2@172.27.43.2): [248605.646709] VAP device aruba100 created osifp: (d95e45c0) os_if: (d87d0000)Jan 18 16:48:40 KERNEL(1F-2@172.27.43.2): [248605.704564] VAP device aruba101 created osifp: (d95e75c0) os_if: (d8240000)Jan 18 16:48:40 KERNEL(1F-2@172.27.43.2): [248605.762351] VAP device aruba102 created osifp: (d95e05c0) os_if: (d69c0000)Jan 18 16:51:21 KERNEL(1F-2@172.27.43.2): [248766.504312] VAP device aruba100 created osifp: (d95e45c0) os_if: (d9498000)Jan 18 16:51:21 KERNEL(1F-2@172.27.43.2): [248766.562754] VAP device aruba101 created osifp: (d95e05c0) os_if: (d84a0000)Jan 18 16:51:21 KERNEL(1F-2@172.27.43.2): [248766.620303] VAP device aruba102 created osifp: (d95e75c0) os_if: (d65b8000)Jan 18 16:58:11 KERNEL(1F-2@172.27.43.2): [249176.347901] VAP device aruba100 created osifp: (dbd905c0) os_if: (dc8f0000)Jan 18 16:58:11 KERNEL(1F-2@172.27.43.2): [249176.406497] VAP device aruba101 created osifp: (dbd975c0) os_if: (d6020000)Jan 18 16:58:11 KERNEL(1F-2@172.27.43.2): [249176.464005] VAP device aruba102 created osifp: (dbd945c0) os_if: (d6010000)Jan 18 16:59:53 KERNEL(1F-2@172.27.43.2): [249279.009243] VAP device aruba100 created osifp: (d95e75c0) os_if: (d6af0000)Jan 18 16:59:53 KERNEL(1F-2@172.27.43.2): [249279.066799] VAP device aruba101 created osifp: (d95e35c0) os_if: (d8f08000)Jan 18 16:59:53 KERNEL(1F-2@172.27.43.2): [249279.123983] VAP device aruba102 created osifp: (d95e65c0) os_if: (d9ab0000)Jan 18 17:06:11 KERNEL(1F-2@172.27.43.2): [ 142.220208] VAP device aruba100 created osifp: (ddf735c0) os_if: (dcf18000)Jan 18 17:06:12 KERNEL(1F-2@172.27.43.2): [ 142.484144] VAP device aruba101 created osifp: (ddec85c0) os_if: (d9d08000)Jan 18 17:06:12 KERNEL(1F-2@172.27.43.2): [ 142.543299] VAP device aruba102 created osifp: (ddece5c0) os_if: (dc980000)Jan 18 17:08:49 KERNEL(1F-2@172.27.43.2): [ 299.787957] VAP device aruba100 created osifp: (dd6995c0) os_if: (d88e8000)Jan 18 17:08:49 KERNEL(1F-2@172.27.43.2): [ 299.845909] VAP device aruba101 created osifp: (dd69c5c0) os_if: (dd6a8000)Jan 18 17:08:49 KERNEL(1F-2@172.27.43.2): [ 299.903275] VAP device aruba102 created osifp: (dd69d5c0) os_if: (dc238000)Jan 18 17:09:33 KERNEL(1F-2@172.27.43.2): [ 343.766391] VAP device aruba100 created osifp: (ddec85c0) os_if: (d8b40000)Jan 18 17:09:33 KERNEL(1F-2@172.27.43.2): [ 343.825656] VAP device aruba101 created osifp: (ddece5c0) os_if: (d89f8000)Jan 18 17:09:33 KERNEL(1F-2@172.27.43.2): [ 343.883330] VAP device aruba102 created osifp: (dd69f5c0) os_if: (d9318000)Jan 18 17:11:44 KERNEL(1F-2@172.27.43.2): [ 474.990660] VAP device aruba100 created osifp: (dd69a5c0) os_if: (dc9c8000)Jan 18 17:11:44 KERNEL(1F-2@172.27.43.2): [ 475.049710] VAP device aruba101 created osifp: (dd69d5c0) os_if: (dc278000)Jan 18 17:11:44 KERNEL(1F-2@172.27.43.2): [ 475.107251] VAP device aruba102 created osifp: (dd69f5c0) os_if: (da458000)Jan 18 17:13:23 KERNEL(1F-2@172.27.43.2): [ 573.971866] VAP device aruba100 created osifp: (ddecc5c0) os_if: (d9288000)Jan 18 17:13:23 KERNEL(1F-2@172.27.43.2): [ 574.029774] VAP device aruba101 created osifp: (ddece5c0) os_if: (d8c70000)Jan 18 17:13:23 KERNEL(1F-2@172.27.43.2): [ 574.087531] VAP device aruba102 created osifp: (dd6995c0) os_if: (d7930000)Jan 18 17:14:36 KERNEL(1F-2@172.27.43.2): [ 646.914287] VAP device aruba100 created osifp: (dd69a5c0) os_if: (d8838000)Jan 18 17:14:36 KERNEL(1F-2@172.27.43.2): [ 646.973641] VAP device aruba101 created osifp: (dd69e5c0) os_if: (d8938000)Jan 18 17:14:36 KERNEL(1F-2@172.27.43.2): [ 647.031211] VAP device aruba102 created osifp: (dd69b5c0) os_if: (d8dd8000)Jan 18 17:21:10 KERNEL(1F-2@172.27.43.2): [ 1040.612803] VAP device aruba100 created osifp: (dd69f5c0) os_if: (d8ab8000)Jan 18 17:21:10 KERNEL(1F-2@172.27.43.2): [ 1040.612803] VAP device aruba100 created osifp: (dd69f5c0) os_if: (d8ab8000)Jan 18 17:21:10 KERNEL(1F-2@172.27.43.2): [ 1040.671762] VAP device aruba101 created osifp: (dd69a5c0) os_if: (d7d38000)Jan 18 17:21:10 KERNEL(1F-2@172.27.43.2): [ 1040.671762] VAP device aruba101 created osifp: (dd69a5c0) os_if: (d7d38000)Jan 18 17:21:10 KERNEL(1F-2@172.27.43.2): [ 1040.729183] VAP device aruba102 created osifp: (dd69d5c0) os_if: (d8768000)Jan 18 17:21:10 KERNEL(1F-2@172.27.43.2): [ 1040.729183] VAP device aruba102 created osifp: (dd69d5c0) os_if: (d8768000)Jan 18 17:24:18 KERNEL(1F-2@172.27.43.2): [ 1229.208440] VAP device aruba100 created osifp: (ddec85c0) os_if: (d8ae0000)Jan 18 17:24:18 KERNEL(1F-2@172.27.43.2): [ 1229.208440] VAP device aruba100 created osifp: (ddec85c0) os_if: (d8ae0000)Jan 18 17:24:18 KERNEL(1F-2@172.27.43.2): [ 1229.267890] VAP device aruba101 created osifp: (ddece5c0) os_if: (d80d8000)Jan 18 17:24:18 KERNEL(1F-2@172.27.43.2): [ 1229.267890] VAP device aruba101 created osifp: (ddece5c0) os_if: (d80d8000)Jan 18 17:24:19 KERNEL(1F-2@172.27.43.2): [ 1229.325184] VAP device aruba102 created osifp: (ddf715c0) os_if: (dc3a8000)Jan 18 17:24:19 KERNEL(1F-2@172.27.43.2): [ 1229.325184] VAP device aruba102 created osifp: (ddf715c0) os_if: (dc3a8000)Jan 18 17:29:12 KERNEL(1F-2@172.27.43.2): [ 1523.047804] VAP device aruba100 created osifp: (dd69f5c0) os_if: (d8ad0000)Jan 18 17:29:12 KERNEL(1F-2@172.27.43.2): [ 1523.047804] VAP device aruba100 created osifp: (dd69f5c0) os_if: (d8ad0000)Jan 18 17:29:12 KERNEL(1F-2@172.27.43.2): [ 1523.105557] VAP device aruba101 created osifp: (dd6995c0) os_if: (da548000)Jan 18 17:29:12 KERNEL(1F-2@172.27.43.2): [ 1523.105557] VAP device aruba101 created osifp: (dd6995c0) os_if: (da548000)Jan 18 17:29:12 KERNEL(1F-2@172.27.43.2): [ 1523.163154] VAP device aruba102 created osifp: (dd69a5c0) os_if: (d8ae8000)Jan 18 17:29:12 KERNEL(1F-2@172.27.43.2): [ 1523.163154] VAP device aruba102 created osifp: (dd69a5c0) os_if: (d8ae8000)Jan 18 17:33:11 KERNEL(1F-2@172.27.43.2): [ 1761.395740] VAP device aruba100 created osifp: (dd69f5c0) os_if: (d8c08000)Jan 18 17:33:11 KERNEL(1F-2@172.27.43.2): [ 1761.395740] VAP device aruba100 created osifp: (dd69f5c0) os_if: (d8c08000)Jan 18 17:33:11 KERNEL(1F-2@172.27.43.2): [ 1761.455915] VAP device aruba101 created osifp: (dd6995c0) os_if: (da540000)Jan 18 17:33:11 KERNEL(1F-2@172.27.43.2): [ 1761.455915] VAP device aruba101 created osifp: (dd6995c0) os_if: (da540000)Jan 18 17:33:11 KERNEL(1F-2@172.27.43.2): [ 1761.513624] VAP device aruba102 created osifp: (dd69e5c0) os_if: (da548000)Jan 18 17:33:11 KERNEL(1F-2@172.27.43.2): [ 1761.513624] VAP device aruba102 created osifp: (dd69e5c0) os_if: (da548000)Jan 18 17:35:57 sapd[977]: <404070> <WARN> |AP 1F-2@172.27.43.2 sapd| AM 24:f2:7f:2f:43:c0: ARM Empty Channel Trigger new 1-0/0 old 11-274/0 new_rra 1/7Jan 18 17:40:01 KERNEL(1F-2@172.27.43.2): [ 2172.168086] VAP device aruba100 created osifp: (dd69f5c0) os_if: (d85a0000)Jan 18 17:40:01 KERNEL(1F-2@172.27.43.2): [ 2172.168086] VAP device aruba100 created osifp: (dd69f5c0) os_if: (d85a0000)Jan 18 17:40:01 KERNEL(1F-2@172.27.43.2): [ 2172.225719] VAP device aruba101 created osifp: (dd69b5c0) os_if: (dc628000)Jan 18 17:40:01 KERNEL(1F-2@172.27.43.2): [ 2172.225719] VAP device aruba101 created osifp: (dd69b5c0) os_if: (dc628000)Jan 18 17:40:01 KERNEL(1F-2@172.27.43.2): [ 2172.283188] VAP device aruba102 created osifp: (dd69c5c0) os_if: (d9a38000)Jan 18 17:40:01 KERNEL(1F-2@172.27.43.2): [ 2172.283188] VAP device aruba102 created osifp: (dd69c5c0) os_if: (d9a38000)Jan 18 17:41:43 KERNEL(1F-2@172.27.43.2): [ 2274.020322] VAP device aruba100 created osifp: (ddecc5c0) os_if: (dd4a8000)Jan 18 17:41:43 KERNEL(1F-2@172.27.43.2): [ 2274.020322] VAP device aruba100 created osifp: (ddecc5c0) os_if: (dd4a8000)Jan 18 17:41:43 KERNEL(1F-2@172.27.43.2): [ 2274.079651] VAP device aruba101 created osifp: (ddec95c0) os_if: (d84d8000)Jan 18 17:41:43 KERNEL(1F-2@172.27.43.2): [ 2274.079651] VAP device aruba101 created osifp: (ddec95c0) os_if: (d84d8000)Jan 18 17:41:43 KERNEL(1F-2@172.27.43.2): [ 2274.137120] VAP device aruba102 created osifp: (d9cdd5c0) os_if: (d9e28000)Jan 18 17:41:43 KERNEL(1F-2@172.27.43.2): [ 2274.137120] VAP device aruba102 created osifp: (d9cdd5c0) os_if: (d9e28000)
Elan Cao
