Hi there,
I got a new issue and I am not sure what to do.
I have been added a new batch of APs (after renovation ) and noticed that all the newly added APs are not discovered by the controller.
When I check the adp i get :
(VNR557WLC01) #show adp config
ADP Configuration
key value
discovery enable
igmp-join enable
igmp-vlan 0
all the APs are getting an IP and I can ping them from the master
#ping 10.128.18.242
Press 'q' to abort.
Sending 5, 100-byte ICMP Echos to 10.128.18.242, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0.735/0.8826/1.108 ms
However , the master never seen them , so I cannot provision them.
I am sure I am missing seomehting here. We did this many many times and nerver encounter this situation.
Thank you for any help you can provide.
